I'm guessing this ain't good ! (G bearings)
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Topic: I'm guessing this ain't good ! (G bearings)
    Posted: 14 Dec 2011 at 1:44pm
Been a while since I've opened an engine or seen the bearing surfaces but I don't think this is a good thing ! There's a knocking coming from somewhere, rod caps all seem the same for play. Figured I'd better get a look at the bearings. This is the number one bearing in my G. Lines on the crank can be felt with a fingernail. No doubt the rest are the same. Guess I need to get an engine stand and figure how I'm gonna get this bugger apart !
This is the cap.
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 1:48pm
 Warren !!  Thats  not  to good    hope it  will grind ok. Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 1:51pm
Yeah, I'm taking pictures over to the NAPA shop to give them a heads up. Will no doubt be getting in touch with you for bearings and such, Tony !
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 2:01pm
One way to look at it-- good winter project,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 4:58pm
Yeah, but I've got three of them in progressively worse conditon !
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2011 at 8:34pm
That looks good compared to the WD-45 i've got apart right now.  Just imagine 4 spun rod bearings and how that looks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 3:14am
Don't be talking like that Cody ! Like I said, I've got this one and 2 others I'd like to get done ! Plus I have one with a busted block that hopefully can be used for parts if needed. (Besides the steering box on a Oliver 550 and head gasket on a Oliver 1600 !!! I hope winter isn't that long !)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 6:47am
Looking at that crank, the oil hole is chamfered. That's a common engine/crank rebuilding practice when grinding cranks and rebuilding engines for better oiling. Unless that's a factory thing on those particular engines. That crank might have been ground already. Well, whatever it is, the extra oiling didn't work well I guess. LOL! What is it with these Continental N62 engines that they are so expensive to rebuild and repair?? Sheesh! Warren, not to upset ya anymore than you are, but that doesn't look good! LOL! Could be alot worst tho. Could've made a window in the side of the block I guess...
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:47am
At least much of the babbit on the bearing is scraped away from the copper. Won't take as long to get the rest off for recycling!
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
