identify this engine and pump
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: identify this engine and pump
    Posted: 11 hours 28 minutes ago at 4:00pm
i picked up this engine and pump with some other parts pump dosnt fit that engine   , what is the engine  and what is the tank on it ? also it has a oliver looking color green paint that is under the orange.   will this fit in my c ?  was this some military spec. engine
Edited by HudCo - 11 hours 18 minutes ago at 4:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 15 minutes ago at 4:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 53 minutes ago at 4:35pm
There should be a s/n stamped on the engine behind the carb or on the left bell housing flange lip.  The engine looks to me like a G-138 or G-149 to a D-10 or D-12. The Barnes pump has a diesel p/n on it. So, maybe a WD-45 or D-15 diesel ? The square drives shaft looks like an old Detroit diesel engine, but the p/n is clearly Allis-Chalmers.
Edited by DrAllis - 10 hours 49 minutes ago at 4:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 21 minutes ago at 6:07pm
Very early series 1 D10-12 engine.Is it for sale? Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 31 minutes ago at 6:57pm
that pump does have kind of a detriot color on the other side
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 11 minutes ago at 8:17pm
oil tank and the bottom  coat of green paint  it must have been some  kind of industrail thing  looking on the internet i cannot find a picture of a pump under the distributor houseing on any d 10 or d12 but looks like there was a pump mounted their
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 6 minutes ago at 9:22pm
The Detroit pump ( if that's what it is) certainly could have been because A-C used Detroit engines in construction equipment up until 1953. The green paint is confusing tho......
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 44 minutes ago at 10:44pm
just looked up the parts on the oil tank  was used on the industrail tractors and ethier power steering pump or auxillery hydralic pump
