I600 forklift dilemma
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: I600 forklift dilemma
    Posted: 11 Aug 2017 at 6:52pm
I just got an I600 forklift running after sitting a couple years. The forks clutch and all that work like it should, but I can't get the steering to work? Where should I start and what should I look for? Thanks in advance.
1950 B, 1952 pulling wd, and 1954 wd45
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2017 at 7:11pm
Obvious place is fluid level. Maybe top up whatever/wherever it needs 'oil'? Assuming power steering..does it even attempt to turn?
It'd be a great idea to get the service manual or maybe someone here can copy/send the 2-3 pages about how the steering works.
I have to admit the FPD50 I have here IS a life saver, paid for itself several times over though they do need some TLC once in awhile.
Jay
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 12:06am
Check to see if the PS has its own pump. My Hysters do and at times they lose my here prime.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2017 at 4:39am
X2 on fluid level check...  Fill port/dipstick is in back of radiator, big plug/vent on right, as you stand behind it
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 9:27am
Just thought I would share, the problem ended up being the feed line to the steering under the tractor had come unhooked and was leaking all the fluid out. Got it all back together and it's working good!
This page was generated in 0.057 seconds.
