I need advise. Wd45 governor/throttle woes.
Feral Donkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Feral Donkey Quote  Post ReplyReply Direct Link To This Post Topic: I need advise. Wd45 governor/throttle woes.
    Posted: 05 Jan 2019 at 5:19pm
Question. When the tractor is not running. Run the throttle low and it pulls on that spring under the governor cover up front. Should it be stretching the spring or should that spring act as solid linkage until the governor influences it? It stretches mine and doesn't move the bottom lever at all. I'm wondering if that cross over tube with the rotating linkage that goes under the fan is full of grunge? Or maybe the spring is old and weak? I pulled out the alternator/governor assembly and that all looks in good repair.
Rewind. Here's my situation. I got my first orange tractor a few weeks ago. Got a good deal on it. The guy I bought it from said the governor would loosten up and start working once I ran it more because it's been sitting a few years. Now when I was driving it around his driveway I could slow the throttle down at the control but not speed it up. Long story short, I took it home and used it and the throttle control does nothing. I set the throttle by putting the linkage on the carb side where I want it, climb on the tractor, and feather the clutch to keep it from killing when it's under a load. That got old and today I pulled it apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 5:34pm
Sitting in the seat, pull DOWN on the hand throttle. The internal governor spring should get stretched by being pulled upwards by the upper arm. At this time, you should be able to grab ahold of the vertical governor arm behind the generator/alternator and force it FORWARD towards the radiator about 1+ inch. This will be working against governor spring pressure. When you let go of the vertical governor arm it should snap back rearwards. This linkage has to be free and not binding anywhere. Can't be a cotter pin not installed properly at the carb end. The link rod to the carb goes close to the block with the cotter pin away from the block. Many novices install the link rod bass-ackwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Feral Donkey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 6:23pm
Yup. Mine is bass ackwards. I just copied it the way it was when I got it. I'll look at it again in the morning. But I think the governor arm does go forward like an inch and snap back. Assuming it does, where do I look next?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 6:42pm
FD,
Dr Allis has given you some things to check. I see you have a picture. So you have removed the govenor/ distributor housing. I assume that the weights move freely? All the linkages can be suspect and worn at the joints too. I had one that had a mind of its own. Had to go through all the linkages and make adjustments and correct worn joints in the linkage system. Also there is a big spring under the tank on the right side. Make sure its hooked up correctly. Pictures can help us help you too.
Edited by Sugarmaker - 05 Jan 2019 at 6:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Feral Donkey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:13pm
Oh yeah. I went in baby steps taking it apart today. I did see the big spring under the tank. The linkage does not look especially worn. Now on the governor lever by the alternator there is a little clip should there be a spring on that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:36pm
Whatever the he77 is strapped to the side of the vertical governor arm....GET IT OFF OF THERE  !!
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 7:44pm
There's nothing attached to that clamp on the governor arm is there? Because there shouldn't be anything there. Looks like a PO was jerry-rigging something to get around past problems with the gov. instead of fixing it properly, I would just take the clamp off. I see there's an alternator on it also, the elbow of that arm looks real close on that side, it's not hitting/binding on the bracket or alt body is it? Check the position of the arm for free movement throughout the range of the throttle lever.
Edited by Bill_MN - 05 Jan 2019 at 7:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2019 at 8:58pm
FD,
First thanks for the pictures. It may help as folks have already seen some things. For some reason and maybe its just the angle of the picture, but the govenor arm looks like it may have a bend in it? IIRC they are straight. that could be affecting the length of the throttle rod to the carb?
Also in the first picture for some reason the governor spring looks twice as long as I remember? Could you get a close up of that? Please.
Edited by Sugarmaker - 05 Jan 2019 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 7:14am
Just because the vertical governor arm is bent like that doesn't mean it's wrong. The key is the synchronization of the arm hole position to the carbs throttle shaft opening. Many arms have been bent like that and some the other way. Synching is key, not what it looks like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 8:47am
Dr Allis,
 I agree, and based on your recommendations, I have tweeked the rod from there to the carb to get the right dimension and allow the governor to preform correctly. I think one of the books I read that bending that arm was the preferred method. I could never figure out how the get a hold on it and bend it without damaging something!:) So I usually put a kink in the rod to the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Feral Donkey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 9:57am
Sugarmaker, that is with the throttle all the way down. It just stretches the spring and does nothing else. Is that supposed to do that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Feral Donkey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 12:45pm
The governor arm barely clears the alternator. My friend stopped over and worked the arm some and we felt it free up. I kept squirting triflow in both ends and it got better and better. Now when I move the lever it moves the throttle on the carb. I'm putting it back together right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Feral Donkey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 12:47pm
Does this stuff look correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2019 at 1:20pm
FD,
Sounds like you have persevered and have found your issue with the governor cross rod being tight.
Also:
Thanks for explaining the picture of the extended spring too. I thought that might be what I was seeing but had never seen it stretched I guess.
Hope it runs much better. The rods and adjustments under the tank look about right. There is a adjustment that can be made if necessary to the length of the rod from the governor arm to the carb. Dr Allis and others are good at explaining how to check this.
