Hydro ram seals
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Topic: Hydro ram seals
    Posted: 17 Apr 2012 at 6:27am
The hydrolic ram that lifts my mower on my B is leaking pretty bad from the cylinder. Does anyone have any information on them or know where I could get seals and or parts for it.
Thanks Peter
5 Steigers, 7 John Deeres, 8 Internationals, 4 Case tractors and combines and 1 Oliver
........... Oh wait they're all 1/64.......and a real '44 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 7:20am
Try tightening the packing gland nut some, see if that helps.  That's all it took for my WD lift arm cylinders.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 10:16am
Baum Hydraulics may have a kit of parts. Almost sure to have the parts individually for proper sealing, but they may be hard to identify. Download the last two sections of their catalog, their on line search isn't very good. Then call them.
Gerald J.
Greg_WJP_(WI) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 10:53am
Peter,
It's a ways away for you, but I took the rams for my CA to a local hydraulics shop in Eau Claire.  They did a pretty good job.  It's called Planert Hydraulics.
2122 Cameron St
Eau Claire, WI 54703
(715) 834-4178
www.planerthydraulics.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 6:05pm
I've tightened that nut as tight as i twill go so thats not the problem, I may try those other place or I may just buy a new one. I may not even use it if I buy a woods mower with the lift because one of the spindles on this deck don't have bearings in it.
Thanks for the ideas though.
George Davenport View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 6:28pm
What is the model of the Woods Mower?  I may have some extra spindles for it.  Also a leather packing kit for the ram will probably cure your leak, especially if the ram is not pitted or rough.  A slight leak is desirable for its own lubrication.
Life is what happens while you are making plans for the future
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 7:17pm
Depending on the rod size and the cylinder size, you could probably buy the chevron packing for $10-$12. If the rod is in good shape it is a pretty simple job to replace the packing. A place like Motion Industries will have the Chevron packing.
REEDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote REEDE Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 7:53pm
All you need is a one stack of vee - packing  7/8 id x 1 od. , do not measurements in front of me.
