Hydraullic question
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Topic: Hydraullic question
    Posted: 29 Aug 2011 at 8:01pm
They say theres no such thing as a stupid question. We have a sweet AC wagon with a single action lift ram. Can you connect a single action ram to a double action modern tractor to lift it and then use the "float position" to lower the wagon?? We will be cutting beans with the 72 allcrop and I'm thinking the cab tractor would be safer driving to the grain elevator the way cars drive nowadays. Ryan
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2011 at 8:11pm
yes. double acting tractors when put in raise sends oil to to the cylinder. in the down position the oil is allowed to go back to the tank through the valve. it may strain a little in the down position as it is trying to put oil out the down side. float will also work as both up and down sides of the valve are dumoing back into the tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2011 at 8:29pm
Thats what I was thinking. Thanks for the help!! Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2011 at 8:37pm
You may have a problem dumping a load with it. If it is a high pressure ram like used with the CA through 45's and early 17's, the low pressure high volume systems that are standard today may try to slam the ram up at about twice the speed of normal but might not have the umph to raise a load.I have a Montgomery Wards barge box with a high pressure low volume cylinder. I have never tried to dump it with a low pressure high volume system. I have dumped wagons with my 45 that had low pressure high volume rams, but you tend to run out of oil in the 45 before you blow the end out of the cylinder.
This page was generated in 0.240 seconds.
