Hydraulic/transmission fluid 7010/7030 |
bleeds orange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2012 Location: mt. vision, ny Points: 692 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Mar 2022 at 6:34pm |
I believe from what I have read, that i can use john deere hy-gard hydraulic fluid to use in my hydraulic/transmission reservoirs on my 7010/7030.
Is this true? Thanks cory |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 86574 |
most high quality trans/ hydraulic fluids will meet 20 different specs.. They should be listed on the back of the bucket... Will be Allison C3, CAT TO2, JD 27xx (?), Allis 821... etc.
Hyguard should be one of the QUALITY oils... check the bucket spec.
orangereborn ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: NW WI Points: 1463 |
Would N series GLEANER fall into any of those spec's?? Dale
Ben (MI) ![]() Orange Level ![]() ![]() Joined: 02 Jun 2010 Location: SW Lower MI Points: 760 |
I have been using Hy-Gard for many years in 7000 series tractors with no issues.
Part time farming with a 1980 7060 and 1984 F3 hydro.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21575 |
Not "N-series" Gleaners, but sometime after 1999 they went away from Dexron (red) hydraulic fluid on the Gleaner line.
Dave974 ![]() Bronze Level ![]() Joined: 18 Aug 2017 Location: Fort Wayne, IN Points: 77 |
Same here. In the past I've used Hy-Gard in my 7010 with no issues. In recent years, I switched to the Premium Trans/Hydraulic oil from TSC and had good results with that too. Both meet the 821 spec.
Edited by Dave974 - 14 Mar 2022 at 10:29am |
'77 7080, '81 7010, '79 L2, '84 F3
Ok thanks
