Hydraulic question
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic question
    Posted: 3 hours 28 minutes ago at 5:00pm
I have a Royal King 37 hp tractor, with the backhoe attachment. If I don't bleed down the hydraulic system, tractor shut down, cycle all controls in tractor and hoe before I disconnect the hoe from the tractor, then I cannot get the quick disconnects reconnected when I setting up to use the hoe again. In that case, I then need to take cover off of controls and open the system to relieve the pressure. PITA!
my question is there something I can put in line that I can relieve the pressure w/o taking it all apart?
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 55 minutes ago at 5:33pm
Have same issue with a 2305 Deere loader attachment, anything functional would be ridiculously expensive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 5 minutes ago at 7:23pm
Dave, I'm sure you are right, but it sure would be nice to have a manual pressure relief that could be installed in line with the two hoses going to the hoe.
Wait for the Lord;
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 59 minutes ago at 7:29pm
pioneer 9500-4 series couplers connect under preasure
