Hydraulic Pump
jcoldman20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jcoldman20 Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Pump
    Posted: 16 Aug 2017 at 9:14am
I have an 57 model B that has had a 3 point hook up added to it.  When using the hydraulics to lift equipment on the rear or in the middle they bounce up and down like the pump is starving for fluid.  The fluid level is full.  Has anyone ran into this situation before?  If so how did you troubleshoot the problem?
Thanks in advance
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 10:59am
First thanks for taking such good are of my favorite.
As to your problem.  First, Check the fluid level again.  Do be certain it is to the fill plug. You may want to set the tractor on an uphill slant - you should have a gasket dam between the rear end and the PTO - so you want to be sure there is sufficient fluid in the PTO housing.  Next you may have air in the hydraulic line.  I would suggest you bleed it again.  We used to do it by loosening the swivel connection and raising the lift.  When the fluid came out full it was clean.
Good Luck!
Bill Long
This page was generated in 0.040 seconds.
