Hydraulic lift |
Post Reply |
Natew15
Bronze Level Joined: 05 Apr 2020 Location: 14469 Points: 6 |
Posted: 05 Apr 2020 at 11:49am |
I have a 1953 WD that has a drop bucket that only rises. When the clutch is released, the bucket goes up until its maxed out. The valve was recently rebuilt to try and solve the issue. Fluid is full, rams are operational and all the linkages are hooked up. Been reading though a service manual but all it says is the hold valve is the problem. Any ideas? Thanks
MACK
The hydraulic pump only works when the foot clutch is released on a WD45. MACK
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18743 |
Put the tractor in neutral, running and try the lever. Does the bucket go up and down?
Are you using the lever on the left side of the steering wheel? Up to the top makes the bucket go up and down to horizontal makes it go down. Moving the lever slowly makes the bucket and the rear lift arms go slowly. With the lever in the middle position, it should lock (hold) the bucket and arms in that position until you either raise or lower the lever. I hope this is clear for you and not as clear as mud for you. |
truckerfarmer
Orange Level Access Joined: 26 Jan 2013 Location: Watertown, SD Points: 3188 |
When you say the valve was rebuilt, do you mean you pulled the pump off the tractor and went through it? Or is it a remote valve that is not original to the tractor?
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
Natew15
When the clutch is released, the bucket only goes up will not lower or hold with the left lever full down. The left lever connects to the hold valve which is what was rebuilt. I'd post pics but they're too big to post. I pulled the pump off after posting to find one of the lobes broke (the spinning part). I assume this would cause the issue? Thabks
Natew15
Natew15
Orange Level Access Joined: 12 Sep 2009 Points: 19714 |
Your pump has ingested some of the iron, sticking the control spools. A massive job of cleaning the oil cavity and throwing a cow magnet inside is in order.
Natew15
Any advice on where to find parts and what to use to clean and replace the fluid with? I'm seeing that SAE 20 oil is recommended.
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5053 |
There are adjustments to the controls on the pump. One setting is for a mounted plow with Traction Booster, which does not have a hold position, the other has a hold position.
MACK
Your local Agco dealer should have the parts. Find the roller assembly at a salvage yard. They are pricey at Agco dealer. MACK
Albert
Silver Level Joined: 11 Sep 2009 Location: NW MO Points: 410 |
P M sent
Albert |
Post Reply | |
