Hydraulic fluid |
one54dodgetruck
Joined: 25 Jul 2011 Location: Chehalis, wa Points: 399 |
Topic: Hydraulic fluidPosted: 16 Mar 2016 at 11:35am |
Do we have any guys that specializes in different oils? Was in the green tractor store picking up parts and was talking with the counter guy about cenex supplying jd hydraulic fluid. He said jd stopped getting it from cenex a while ago. At one of their conventions he said they were told that quick lift was the worst in a jd causing brake and clutch failing. I don't belive this guy, so what's the best hydraulic transmission oil with the best additives for your money?
2 WDs
B B112 D14 D15 shuttle 180 185 7040 Hd7w D14 D15 185 7040 pd |
one54dodgetruck
Posted: 16 Mar 2016 at 11:36am |
Ps I've mainly used orilliys premium hydraulic transmission fluid with no problems, but it's been in little tractors.
2 WDs
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 16 Mar 2016 at 12:03pm |
we have been using Cenex quicklift HTB since 1992, dont know prior to that.
ZERO clutch, brake, hydraulic issues 3020 JD was main feed tractor from 1992 until replaced in 2008 with Rt100. We do run Agco fluid in RT100 with CVT but everything else is HTB
Edited by CAL(KS) - 16 Mar 2016 at 12:06pm |
NEVER green
Posted: 16 Mar 2016 at 1:08pm |
Says on side of pail,Cenex HTB has twice the gear load carrying ability, and four times the copper protection of OEM oil.
MACK
Posted: 16 Mar 2016 at 9:54pm |
If JD don't use it any more, i'm sure it is not any good now. lol MACK
michaelwis
Posted: 16 Mar 2016 at 11:07pm |
Used HTB for as long as I can remember..
What was your question.? Lol Just drained systems of four tractors went through quite a lot |
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60 GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
one54dodgetruck
Posted: 17 Mar 2016 at 12:00am |
Cool. Just wanted to make sure no one else is having issues with quick lift besides mother deere. I'm working on a 4240 jd with the pto slipping, and just got done with a 4020 powershift that I had the clutches out and put quick lift in.
2 WDs
HD6GTOM
Posted: 17 Mar 2016 at 12:10pm |
The guy is probably feeding you *^&*%. Those oils are made to JD's specks. So if there was a problem it would have been with JD specks. Quality control is next to none. I've been in the blending plant years ago.. You could have eaten off the floor anywhere in the building.
