hyd pump gasket WD45
Vinnie/S.D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vinnie/S.D. Quote  Post ReplyReply Direct Link To This Post Topic: hyd pump gasket WD45
    Posted: 26 Nov 2009 at 12:32pm
This is on a WD45 Allis.On the hyd pump the gasket on the right end of the pump (four bolts holding it on) I keep blowing that gasket out and the oil just gushes out, What am I doing wrong? The gasket I put in is a very thin one, try to tighten all the bolts the same tork???? vince/s.d.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 7:30pm
Vinnie - I assume you are refering to the small plate that holds the control valve and the unloading valve in-place.  You need to put new O-rings on both.  That should solve the problem.  -  Al    Happy Thanksgiving!!
This page was generated in 0.297 seconds.
