How to remove dents from a radiator tank?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: How to remove dents from a radiator tank?
    Posted: 15 Mar 2021 at 9:15pm
Anyone have any ideas?  The top tank on my G has many dents in it.  Aside from the dents, it is in perfect condition.  My local shop cleaned and tested the rad and did not have any reason to remove the tank.  I took it to my body shop today and he did not think body fill would hold up well on a copper tank that can get pretty hot.
Any ideas on how to make this look better?
Edited by DSeries4 - 15 Mar 2021 at 9:16pm
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 9:34pm
My Humble Opinion, unless you are restoring to show quality, I would leave well enough alone. Just about anything you do, short of a professional removing the tank and repairing, is risking a bigger mess!
That said, if you still want to try, I suppose you could, maybe, manufacture some tool to wiggle through the filling port and under the dent to buck as you tap the dent out.....but, I would leave well enough alone. If it is working, resist the urge to fix it.
Edited by LouSWPA - 15 Mar 2021 at 9:35pm
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 9:37pm
I am restoring to show quality.  The way it looks now is not gonna pass muster.
T Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 10:05pm
The way I've always done them is I solder a pin on there and use my slide hammer and just bump the dents out the best I can. I use 60/40 radiator solder....the more lead the less chance of breaking any other solder loose with heat. Then you can just heat and remove the attachment pin. After that go "old school" and lead up the remaing dent and work down like they did back in the day or like your bondo/filler.
Disadvantages are... top has to be clean clean to assure bonding of solder or lead. Lastly you will be working with a "toxic" material and take all precautions to protect yourself.
You will have to paint it back black to cover the lead/brass look.
Just my two cents
C in Concord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C in Concord Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2021 at 10:17pm
Powder coaters use high-temp body fillers.  One example is Eastwood's Lab Metal product.  Personally, I'd attempt a paint-less dent puller (glue on anchors that you can grab with a slide hammer).  Worked pretty well on my truck door after a joust with a run away cart of rain gutters in the parking lot of my local building supply.  Pullout what you can and move on.  Perfection is the enemy of good.
Ben
Leave things better than you found them.
1941 Model C (restored 2020)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 6:54am
options....
1) I'd have the rad shop remove the top piece( header ??) then take an hour or so and 'metalwork' the dings out from the back side. It's thin tin, so real easy to do.
Once satisfied it's 'show quality', then have shop reassemble the rad.
2) Now true 'old skool' fix would be to 'lead' the divots, same as 50s body guys did repairs to car bodies. Clean the header real good(bright and shiny), flux, heat, pool on the 'body solder', file smooth, paint.
#1 would be the 'proper way', #2 is the 'easy way'
#3 maybe use shortstrand firbreglas, need to lookup the temp rating though, rad might get say 200*F ? FG is used a LOT for high temp stuff...'should' be OK though...
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 10:31am
The brass tanks on these old machines is very thin.
Trying to remove the tank and dolly the dent out is the most expensive way. And you will still be left with minor dents from the dolly and hammer, plus the brass has many many heat cycles on it so you also may end up with tiny cracks.
Filling the dents with solder,and then reshaping to factory shape will probably be your best bet.
   Unless you plan to strip the paint and polish the brass this is probably the most economical way.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 12:13pm
The only way to get show quality is have the tank removed from the core work it back to original and have the tank reinstalled. Your radiator guy will not like you and it'll cost more than buying a new one. Any other way is just half assed
SEIA Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SEIA Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2021 at 8:17pm
I had the same dilema with my WC radiator.  Took it to a radiator shop to have a new core soldered in.  Dropped it off when he wasn't there, so never gave him instructions.  Got it back after 2 weeks with a big ole patch soldered on top and a bunch of globs in the lettering on the front where he patched some pin holes, and the dents were all there yet.  I didn't say anything because it was partly my fault for not telling him how I wanted it done, besides, it would've cost even more to fix.  I just paid the almost $600 bill and took it home.  I got on Youtube and watched some videos, and taught myself how to solder.  I ended up melting the whole thing apart, and after pounding out the dents and soldering the pin holes on the inside, I soldered it all back together with a new copper drain tube, and after a week of working on it, looks pretty good all painted up.  Should've got a new core and did it myself in the first place!  Lesson learned the expensive way!
This page was generated in 0.039 seconds.
