How to ID S/N
maddox_kid View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maddox_kid Quote  Post ReplyReply Direct Link To This Post Topic: How to ID S/N
    Posted: 08 May 2012 at 7:10pm
Can anyone tell me where to locate the s/n on a vintage AC tractor.  I have located the tractor no in the area of the gear shift.  Do not know model or year.
Thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 7:14pm
If you found a number stamped near the gear shift where it says Tractor Number you have found the serial number and it starts with the model . B12345 is a model B, C12345 is a model C, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 7:22pm
You can find the year of production here, just be aware the number listed for the early tractors thru 1957 is the last tractor of the year: http://www.allischalmers.com/serials.html
The engine should have a different serial number and will most likely be stamped on the left rear flange where it bolts up to the bell housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote maddox_kid Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 7:45pm
All,
  Thanks for the prompt replies; but, the tractor no I wrote down does not contain a letter only the numbers 3125026.  I will verify.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 8:01pm
Wire brush it off good and take another look. B125026 is a 1955 model B.
Post a picture here for us to look at. We like picturesClap
There were 3 models that had a tractor number stamped by the shifter, none had a serial number that goes to 3125026. I'm sure the first stamp is a B.
Edited by CTuckerNWIL - 08 May 2012 at 8:05pm
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 8:02pm
What model of 'vintage' tractor do you have... that will influence where the numbers will be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 8:07pm
 He says he located the Tractor Number by the shifter so it is a B,C or CA and with the number he just posted I believe ha has a 1955 B.
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 8:35pm
What part of MD are you from? If your in Carroll or Balt. Co i may be able to take a look at it for you.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote maddox_kid Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 6:15am
All,
  Thanks again.  I will verify tractor no.  BTW, I am originally from Maddox, MD in St. Mary's Co; but, now live in Charles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2012 at 6:52am
Your first number 3 is probably a "B" as Tuck said. Give r' a good cleanin' with a wire brush...
