How to get rid of engine flutter - 7010
Roscoe62 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roscoe62 Quote  Post ReplyReply Direct Link To This Post Topic: How to get rid of engine flutter - 7010
    Posted: 06 Jun 2017 at 5:52am
          This is the one with the Simms pump...  (a previous owner said the original purchaser had the dealer convert it when new - don't know why)
At full RPM, flutters bad just after topping a hill, when the load lightens a bit.  It has always done this a little, but really got bad this weekend.
Engine has ~ 5000 hrs, 7010 PD.  Fuel filter is almost new.  An AGCO dealer shop put injectors in just before I bought it, maybe 750 hrs ago?   It has an electric lift pump, which is new, maybe 100 hours on it.
Nothing else has been done to this engine as far as I know.  Turbo looks original.
Thanks,
Roscoe
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 6:06am
Does it do it at any tempature? Or just when warm? My 7080 did the same thing when warm, adjusted the valves and it went away.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 8:23am
My guess....Simms governor are crude and wear out early.Bet that's what it takes to fix it.Ed would know.
