How much smoke is too much??? |
Author | ||
OrangePowerGA ![]() Bronze Level ![]() ![]() Joined: 24 Mar 2010 Location: GA Points: 181 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Aug 2012 at 6:52pm |
I found a 5015 that I may go look at. I talked to the guy that is selling it for a friends. He said it will smoke for a minute or so when it's started. Is that too long for that model tractor? It's showing about 770 hours on the meter; no the meter does not roll over at 999....they will go past 1,000 I asked about the smoke and what color it was...black...white...blue. He said it was a mix of all. That got me to thinking that wasn't too good. Then he said he believed that the owner would use ether sometimes to start it. The part about the ether make me want to run away. Should I do so? The asking price is a little over $2,000. I know parts can sometime be hard to find for a 5015.
The tractor is about 100 miles away from me; I don't want to waste my time if you guys think it would be a bad idea to buy that machine. Thanks!
Edited by OrangePowerGA - 01 Aug 2012 at 7:15pm |
AC - WD
JD - 650 |
Sponsored Links | ||
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4818 |
that could be an expensive engine to repair, be careful
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
PlayGun ![]() Orange Level ![]() ![]() Joined: 18 Jul 2012 Location: Bulls Gap, TN Points: 399 |
I don't know much about that model, but if it is a diesel white smoke usually indicates bad injectors, allot of times they will stick when they are first started until the oil gets warmed up and builds pressure in the injector. But the blue smoke is not a good sign at all, that's usually oil being burnt.
Hopefully Future AC Man! Ride With Jesus my friends! Lonas
farmtoybuilder ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Dresden,Ohio Points: 1457 |
RUN AWAY FAST. These motors don't need ether to start when they are good! And ether is a NO NO on them !!!!!!!!!!!!!! It ruins Them. It probably has cracked ring glands by now. You would spend a few thousand getting overhauled.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
He is not using ether to start it. It would be a starting fluid. I have not seen ether starting fluid in years. If he is having a problem with starting it would be bad pre hearter or a bad connection to a pre heater. If that little diesel engine has a bad heater it is going to have white smoke on startup. If you get in a hurry and try to start one of them before you have enough heat they will smoke on start up. That is just the way it is. I bought two new heaters fo my 5020/9523 and when I went to replace the old ones I found the first connection bad and the heaters were good. I used starting fluid to start it for months before I got new heaters and that was ten years ago. No problems. Good price. Go get it. My bet is you will never be sorry.
DL you got Lucky using starting fluid on it! Have redone quite a few little Japanese diesels because of it. I would defiantly check out the motor before buying, As you can spent $3000 or more due to high cost of parts if you can find them. They are a Great little tractor, But lack of parts and high cost most of us buy a different brand if using it every week. I love our AC's But we use JD&Kubota's for our everyday use tractors. |
I see your a bunch smarter than me but Being 74 and around this stuff all my adult life I learned many years ago that if I do not put to much mustard on a brat it don't run down my bibs when I take a bite. Same with starting fluid, silcone gasket maker and a bunch of other stuff. Just a sniff will do the trick.
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2516 |
Got to agree with Dick on this one. Ether(starting fluid), used correctly, will not harm an engine. Use it incorrectly and it will cost you.
BTW, I sell Penray starting fluid, 50% ether content, closest I have seen to ether in a long time
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
Sorry I should have thought before I wrote my 1st post to DickL on using starting fluid-ether. And Don said it ALL in his last post, using it "CORRECTLY" Not many owners of these compacts know much about them! Most just know where to put fuel, check oil, turn key and start it. :) Some do a little maintence grease, change engine oil check things. But most just run them all season and then call us to come service it each season, others wait until it quits or has a problem. We've had some fill them with gas. And wonder why it quite running! I could tell lots of stories on these type of owners! All i was trying to say you shouldn't use it on them. Even correctly isn't good on them due to the high compression. And we've had them fail from some owners using starting fluid-ether Incorrectly on them.
Hopefully Orangepower can check it out and decide what's best for him.
Edited by farmtoybuilder - 02 Aug 2012 at 3:38pm |
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
I have used starting fluid on every motor to man. I have always heard dont do that. I have yet to hurt a motor. If you have AC tractors and they are not plugged in,in the winter, you will use starter fluid or you wont move them.
IG
I made an error in my original post. The tractor only has about 470 hours on it. After thinking for a while, if the hours are correct, that tractor should start right up and run like a top!
I did some additional reasearch and found out that a crank can cost as much as 2 grand. So if something major happened, I'd just have to park it or sell for next to nothing as a parts tractor. I'm going to look at a Deere tomorrow morning. Please don't hate me for it guys! I don't want to end up something that is impossible to find parts for. Deere dealers are everywhere and it's hard to beat their parts/service/dealer network. And if I ever wanted to sell it, I'd get better money due to the fact that it's a JD. I just sold my Allis 5040 and took a little bit of a beating on the sale price....lesson learned. Don't get me wrong, I love ACs, but that's the facts and reality. I'd love to get an older Agco-Allis, but AGCO dealers are next to none here in GA. Thanks for all the comments, I'll be steering clear of that 5015. I failed to mention that it had some stuff rigged up by the owner...that's typically not a good sign. That tractor could go from 2 grand to scrap price with a single break down...no thanks.
Edited by OrangePowerGA - 02 Aug 2012 at 4:43pm |
AC - WD
JD - 650 |
I am not at all trying to stir the pot, but allot of people ( I have witnessed it) don't have the knowledge you guys have and cram half a bottle of starting fluid down an engine to start it. I have offered my advise to a couple of my friends and they say " I always use this much" lol, just saying, you guys know tractors, allot don't.
Mike_426 ![]() Silver Level ![]() ![]() Joined: 07 Dec 2011 Location: Ypsilanti Mi Points: 138 |
Its ok, those have Allis paint but aren't really allis tractors anyway
G, 200, 8050 mfd, D17, 195 chainsaw, c-wide front
Steve Bright ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Martinsville, I Points: 2107 |
Those 5015's will start without starting fluid, But you must use the pre-heater, even in the summer time if you pre heat they start
Yup, Thats what I said! The heaters can be good but if they loose there connection from corrosion or the thumb nut gets loose they will not preheat. If you don't preheat enough they will smoke on startup for a few seconds because it draws in fuel that does not ignite before starting. With 440 hours I sure would snap it up if I had a need for one that size. In the summer time I count slowly to 40 before trying to start my 9523/5020. In the winter I count to 100 before trying to start.If I was to look at that tractor I would take a volt meter with me and make sure the preheaters were working before trying to start it. When the switch was turned to preheat and if it didn't have power to the heaters I would rig a jumper wire to the heaters. Also after the engine warms up it should start without preheat after shutting off.
They will white smoke if they are slightly out of time also.
