How much should I give for a 63 D19 D?
RDS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RDS Quote  Post ReplyReply Direct Link To This Post Topic: How much should I give for a 63 D19 D?
    Posted: 20 Aug 2012 at 1:01am
I have come across a 1963 D19 D that was once my father's. I have the chance to purchase it, but want some input on what I should offer for it. It has set in a machine shed for about 15 years. It is missing the turbo , intake , and manifold . other than that it is all there. I want to completely restor it. i have lots of memories with this tractor . Its a match to our 63 D17 that we have had on our farm sence it was new. Amy help would be great .
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 4:23am
If its your fathers i would give a little more.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 4:58am
I sold my grandfather's, about 5 years ago, it was in running shape, with a NI loader, got $4500 for it.  Keep in mind the market has obottomed out, since then.  I would say, in that shape, minus a turbo and manifold, 2 K would be about tops (leaving out the sentimental value).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 5:12am
Sounds about right, the 19 diesels are bringing very good money
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 6:08am
It may be hard to put a price on sentimental value, but it's always better to keep a level head. I found our old WD45 for sale  and it was in rough shape for $2500. I walked away and found it a year later and paid far less.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 7:38am
What kind of shape is what's there in? Why was the manifold, etc. removed? I know it has great sentimenal value but I would assume the engine will be needing a very expensive overhaul along with replacing the missing parts. Tires cost major money too. Money may not be an object in restoring this tractor once you own it but it will limit what it will be worth to any other buyer. My first thought without seeing the tractor would be $900 to $1000 if the tires are decent and the sheet metal is good. If it has a factory 3pt I'd say $2000 in the same condition. Good luck!
AGCO My Allis Gleaner Company
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 9:00am
Value is dependent upon a lot of factors. Factory 3 point, rust free spin out rims, and decent sheet metal (and all there). Since the engine does not run you can't assess the condition of the tranny, power steering, clutch, and brakes. $1,000 sound about right; maybe more if the rubber and rims are in good condition.
Does the seller have an asking price? If so, your offer should be reasonably close to their asking price. If they don't name an asking price 1st and want you to make an offer; good luck. If this is the case, consider the 1st offer to be close to scrap value plus a little more if the rubber is good. If the seller does not like your offer, then counter with "how much would you want for it?"
Sentiment aside, the cost to restore will be in the neighborhood of $3-4,000 (not counting your time and "running around" costs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 9:59am
Keep in mind that it will cost $3000 to $5000 to overhaul. There's a reason the manifold and turbo are missing and I'll bet it's not a good one...
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2012 at 3:24pm
I would give 1000 to 1500 depending on tires. The skys the limit if it has that many memories for you. If I could find some of my fathers equipment I grew up on it would be worth more to me than anyone else.
