High Float Front tires / NF WD |
Post Reply |
59f100292
Bronze Level Joined: 11 Dec 2011 Points: 63 |
Posted: 31 Mar 2020 at 11:49am |
Brainstorming here: I've got some real wet fields, whats the largest front tires that will fit on a narrow front WD? It has standard rims, current tires are 5.50-16. I could flip the rims wider to make room for width from the spindle but that won't cure height restrictions with the frame. Any one go down this road? A tire thats a good bit wider, but not much taller and still fits on the original rim?
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1758 |
600 or 650 16; will be tops. or it will rub at the top. with stock rim's.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4415 |
Here in the clay, narrow front end tractors would tend to "plug up" with wet clay between the tires and tend to slide. I think that's one reason NFE tractors weren't very popular hear in later years.
allisbred
Orange Level Access Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Will you be adding any weight to the front end? Make sure the front tires are not filled with fluid currently. I can pretty much go across water laying on top of clay ground here with a 45 if there is any sod on it.
Edited by allisbred - 31 Mar 2020 at 1:53pm |
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11238 |
One of the ‘50s era GM cars had the same bolt pattern as the Allis 5-bolt. I ran a lot wider tires with them at one time.
Bill_MN
Orange Level Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1463 |
Install a mud scraper whatever size you get, I've had a lot of mud buildup while plowing at our summer show even with mildly sticky black dirt. They can be found at most swap meets and ebay.
tom51
Bronze Level Access Joined: 04 Apr 2019 Location: USA Points: 42 |
Used to flip WD front tires to help in muddy fields didn't put on wider tires though
WF owner
I had forgot about Dad doing that. Thanks for refreshing my memory !
Post Reply | |
