Help with WD year
ray55125 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ray55125 Quote  Post ReplyReply Direct Link To This Post Topic: Help with WD year
    Posted: 02 Oct 2018 at 1:53pm
Just purchased a WD. Was told it is a 1953. Serial number is WD13793. Only 5 digits. I have scraped the paint and that is all that is there.
I am new to forum and to tractors. Appreciate any help to figure out what I have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 2:00pm
If it is a 1953 it will have the curved gearshift with faster 4th gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 3:53pm
Chassis # WD- 13793 would be a 1949 with a straight gearshift.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 4:45pm
I thought that six digit Serial Numbers were 1952-1953.  Is the listing below accurate?
                                          1948              9
                                          1949           9280
                                           1950          35471
                                           1951           72356
                                           1952          105216
                                            1953          131273
  It is my understanding that these would be BEGINNING serial numbers for years listed.  R. Musgrave
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 7:26pm
1949 WD.  But look at the right side of the engine to see if there is a plate bolted on.  It runs from the front to back of the engine.  If it has that plate it has a WD engine.  If it does not have that plate it has a WD45 engine and a few more hp.  A friend of mine has WD and didn't know it had the 45 engine until I noticed it.
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2018 at 10:42pm
Growing up dad had a WD45 and my uncle had a very late WD. The WD had the curved shift lever (and constant mesh trans) and I am pretty sure the engine block did NOT have the RH side cover plate.   What I am trying to say is the lack of the side plate does not guarantee it is a WD45 engine as it may still have the WD engine with a 4" stroke.
Edited by pirlbeck - 02 Oct 2018 at 10:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 9:10am
Just because a WD or WC has a WD-45 block (no right side lifter cover plate) does NOT automatically mean it has WD-45 internal engine parts.  This is especially true if there is no engine serial number stamped on the left side behind the carb/carb hose area.  At some point in time after July of 1953, the old WC/WD/WF engine blocks were discontinued and you were forced into buying a newer style WD-45 block as its replacement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 9:32am
I think that the very late wd's came from the factory with a block without the plate, but yet had a 4" stroke. I remember discussing this with an old time AC mechanic when I worked at the AC dealership in the early 70's
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 10:44am
OK. If that is/was true, there would be a serial number stamped on that block. My Dad had a 53 WD with battery ignition, tall cylinder head and curved gearshift and it had the older WC/WD block in it.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2018 at 7:26pm
WD's came with curved shifter and 45 transmission in 1953 at approx. 127003.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2018 at 9:41am
FROM the factory, DrAllis is correct.  It would have had the serial # stamped.
IF if was a dealer insert, chances are that there is no number stamped.
You WON'T know unless you tear into the engine.
ray55125, as per your question, you have an early 1949 model WD tractor.  At least the rear end of said tractor.  Plain and simple, irregardless of what engine is in it.
It is a work horse and a very good first tractor.  Easy to work on and a lot of fun!!
Ask ANY question you want on here, you'll get some great answers.
WELCOME to the fourm and the world of ALLIS-CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ray55125 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 7:20am
Thanks for all of the help. Looks like I have a 1949 even though the previous owner said 1953.
Are the s/n listed the end of the year sequence or the beginning? I have been told both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 7:22am
Depends whose s/n list you are looking at. I've seen them both ways.  Some just list how many total units were built in a certain year.  Your's is a 1949. That isn't going to change regardless of which list you look at.
