Help with tires |
orangeman Ia ![]() Silver Level ![]() Joined: 24 Jan 2010 Location: Cedar Falls Ia Points: 77 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Aug 2012 at 8:10am |
I have a 6-00- 16 tube tire and I can't see on the tire what the correct air amount is, you guys know? Thank you.
bill2260 ![]() Silver Level ![]() Joined: 30 Mar 2010 Points: 217 |
What are you going to use it on? I run 40 pounds in hay wagons. Front tire on tractor 40-50 unless using loader then 70. Bill
The front tire on my 45
No loader 40 pounds would be max. Depends on how she steers. 32 might be enough. Bill
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41980 |
Most of that size unless it is 6 ply or truck rated would be 32 PSI.
patrickmull ![]() Orange Level ![]() ![]() Joined: 11 Jan 2011 Location: Casey IL Points: 893 |
i run 40 in mine
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Front tires on WD 45 are 25psi. 12 psi in the rears
