Help Needed To Replace Main Seals in WD-45
1terrygladys View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1terrygladys Quote  Post ReplyReply Direct Link To This Post Topic: Help Needed To Replace Main Seals in WD-45
    Posted: 26 Nov 2016 at 6:39pm
Dear Forum Friends,
My favorite tractor of all time, the 56 WD-45 that I grew up on, is leaking terribly from the front main seal.  Also leaks some from the back one.  I have never torn an engine down in my life, but there is no mechanic around my old home place to do the job.  So I'm considering doing the job myself, with your help.
First question (probably seems dumb to most of you) is:  Can I replace the front seal without tearing the engine down?  Any way to replace that seal from the bottom if I remove the pan?
I've looked at the video about replacing these seals on this site a couple times, and it will be very helpful.  But I'm still vainly hoping I can come up from underneath for the front one.
Whaddaya think?
Thanks, Terry
WD-45, WD, Unstyled WC, SC Disk, JD 4430D, JD 4010D, JD B, Iowa pastor & disciple of Jesus Christ
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 7:14pm
would reccomend pulling the engine, put it on a stand, take pan off and replace pan gasket and rear main. rear main bearing cap has the main seal in it.
phil
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 8:23pm
Front seal could be done in chassis. Rear seal the engine has to be pulled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1terrygladys Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 9:10pm
Thank you for your help!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2016 at 9:33pm
When you get the rear main out, get back on hear and some one will give you the do's and don't's before you start back togather.   MACK
