Help Deciding on which tractor
mosstrumpet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mosstrumpet Quote  Post ReplyReply Direct Link To This Post Topic: Help Deciding on which tractor
    Posted: 19 Jul 2021 at 11:54am
I am looking at 2 different AC's, Model B and CA. Both are priced the same. I already have a 3 point brush hog so 1 is obviously more useful out of the gate.
initially it will be used for brush hogging, and eventually hobby farming.
Model B Wide Front. Needs gas tank cleaned and sealed & needs new brakes( I am capable of these repairs). It is converted to 12 volt with New battery. Has underbelly brush hog and finish mower but are not complete and possibly not all components to mount on tractor. It has brand new rear tires. It is confirmed running on an auxiliary gas tank.
Model CA - Tricycle front. Has been shed kept. It was Running when parked 2 years ago. (famous last words) it needs a new carburetor - not rebuilt. has original 6 volt system. may need a new battery but battery was new 2 years ago. New Points, distributor cap, and wires. Has a 3 point hitch. 1 new rear tire, but other tires are servicable. No confirmation that it will start up now, but according to seller should with a new carb.
My land is flat with only a few smaller ditches that are not steep but more rolling. I have always heard the warning of tricycles tipping but again user error and ability of machine must be taken into consideration.
I would ideally like a 3 point hitch. I know the B would benefit from an overrun clutch. but the kit is 500 and the clutch is around 70.
Wanted to get others thoughts on which would be the more useful machine given this above information.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 12:02pm
As much of a B guy that I am, I would think for your usage, the CA would be the better choice just with the accessories the CA has over the B. Just my opinion. If I was in that situation, I'd probably would buy both cause' I wouldn't be able to pass up on the B!  LOL!  That's just me......
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 12:57pm
We have a CA, heavier, 4 speed trans, 3 point, hand clutch. No brainer for me, the CA. It’s also a 2 plow tractor.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 1:22pm
What size is your brush hog and what are you mowing with it? Out of the (2) you mention, CA would be the minimum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mosstrumpet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 1:32pm
My brush hog is 5 foot and I have about 8 acres that had been used for hay production years ago and needs to be tamed a bit.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 1:33pm
I have a B. Get the CA hands down its a far better outfit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mosstrumpet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 1:36pm
This is the Model B
This is the CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 1:55pm
I love the Bs, but the CA has quite a few advantages with its hydraulics, 3 point, and 4 speed........ one question is the hand clutch... Great if it works... Pain in the Ars if it dont and has not been repaired yet..
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 2:32pm
For what ya gonna do,I say get the CA,what all the others said,AND power adjust rears...
Post Options Post Options   Thanks (1) Thanks(1)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 3:26pm
Ah come on guys, this is EASY...
you buy BOTH !!!!
Problem solved..well until the missus finds out...
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 3:43pm
The B will turn over more easily than the CA if that worries you.Anyway I'd take the CA hands down no contest and I'd be looking for a pull type brush hog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 4:18pm
those are both Nice, Straight tractors !
34 Airflow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 34 Airflow Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 6:19pm
Reading your situation the CA would be the ideal working tractor, but jaybmiller is right, grab them both as they look good machines.
I have a C rowcrop tractor that I have done plenty of work with (admittedly on flat country) and even after a small altercation with a drainage channel I've never come close to being unstable.
1937 Model A, 1937 Model U, 1929 United, 1945 Model C, 1949 WF, 1948 WC, 1956 D272 and a Roto Baler
http://www.australianallischalmersregistry.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 8:56pm
The B obviously has a fuel tank issue, hence the side saddle plastic tank. Wrong style seat also. Plus the CA is worth more if they are both in good mechanical condition. The CA is a much more versatile tractor. Again, the CA hands down.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 9:52pm
I have the perfect solution, buy the B for a fun restore, buy the CA for the same reason and then go find a WD which is a far better choice for running the brush cutter. I say this because buying an old Allis is like eating a potato chip. Do you eat just one chip? Satisfy the fever early. Wink
Wink
I am a Russian Bot
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 12:13am
CA for sure. Spin those rear rims out for added stability. Tge narrow front enables tighter turning.
D17 Series 1
Allis B- 1939
Allis B- 1945
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 6:46am
Quote:
"My land is flat with only a few smaller ditches that are not steep but more rolling. I have always heard the warning of tricycles tipping but again user error and ability of machine must be taken into consideration."
One of the things to remember is that the CA is about a foot wider at the rear to start with. Also, as was pointed out above, you have the option to "spin" the power adjust wheels out for maximum width.
With the added width, the CA will be much more stable on sidehills.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 7:01am
Well I own both a B and a CA, as far as putting a 3ph on, the CA is easy, never tried putting one on the B as it is used to cultivate sweet corn.  The CA has more power plus the hand clutch.  I pull a 6' finish mower on my CA narrow front.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 8:01am
CA hands down.
anybody know if the CA 4 speed allows for a slower tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mosstrumpet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 9:57am
Thank you all for the Great Feedback. Obviously I would love to have both but the comment about the wife hits way to close for home! I'm pickup up the CA today, and as mentioned this will likely not be the last tractor purchase.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 11:47am
I guess I’m a little bit too late to help with your decision but I couldn’t make my mind up either and that was 18 Tractors Ago with more coming soon🙀😁
Blue Skies and Tail Winds
                          Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 12:15pm
LOL   Clap
JSHIVERS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JSHIVERS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 7:37pm
I just bought my 1st tractor and it's a B.  It's just for fun, and with hand brakes, hills make for are a real exciting ride!  But I love the old girl.  That said...From what it sounds like your work it is destined for, the CA is probably the better bet.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 9:13pm
Of the two I would go with the CA  4 speed, slightly more HP.. But an even better choice would be a WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 5:47am
CA is a better looking tractor, IMHO.  That being said, a 3 point hitch and a heavy bush hog might make the front end light.  Start looking for FE weights, and a way to mount them...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 6:14am
With that deal, tell the seller to toss in that 37-38 Chevy coupe in with the deal to!  Ahh, again, that's just the hotrodder in me......  Sheesh, I'd be running outta' room if I was me purchasing stuff...   LOL!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 6:18am
Originally posted by corbinstein corbinstein wrote:
CA hands down.
CA as a lower 1st gear than a B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 6:47am
Buy them both, then sell me the CA!
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2021 at 10:54am
The CA is much better than the B for what your wanting to do, however the CA is extremely light in the front end with a 3 point added on. You’d be better off finding a WD, probably same price, but much heavier and the hand clutch is so much better.
However I do have a CA and like to operate it, but I try to find the original snap coupler implements to use with it.
Good luck with your decision, your buying the right color either way.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
