Help a Novice Out
meteorbrews View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote meteorbrews Quote  Post ReplyReply Direct Link To This Post Topic: Help a Novice Out
    Posted: 18 Oct 2015 at 11:23am
Hey All,
Could someone help a novice out and clear something up for me?  Lately, I have been taking off and putting on the battery cables for my B in the wrong order, not the wrong way, just the wrong order, taking the ground off second and putting the ground back on first.  Now, I haven't done any damage to myself, thankfully, but would I do any damage to the electricals in doing such a thing?
Thanks,
Brad.
39/43' Franken B
Amature Homebrewer and Allis Chalmers Novice
Dan73 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2015 at 11:31am
Nope it is just safer to unhook the ground terminal on a battery first incase you hit the frame when you unhook the non ground terminal.   In fact with cars with computers I think they recommend that you unhook the hot side first so that you don't have non grounded electronics.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2015 at 11:49am
I have never, ever seen where anyone recommends that you unhook the hot side of a battery first for any motor vehicle. Safety trumps all other considerations. Your wrench can slip from the ground terminal and hit a metal part of your vehicle and it does no damage. Let that wrench slip and hit the frame while unhooking the hot terminal first and you'll be holding a handful of fireworks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2015 at 11:53am
Well my brother was a GM mechanic in the 80s when the first electronics went into them and he gave me heck for unhook in the ground first said I would blow the computer he had the service notice from GM about it. I told him I didn't care for the same reason you mentioned it is safer for me to unhook the ground first.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2015 at 12:33pm
No matter how you unhook the battery on a B, I'm pretty sure you won't hurt any computer.
One of the big reasons to unhook the ground first, is to avoid sparks. A battery gives off (potentially) explosive gases. A spark can lead to a nasty battery explosion that sprays acid everywhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2015 at 12:52pm
IMO unhooking the hot terminal first and causing sparks is more likely to blow a computer than merely unhooking the ground terminal first.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 6:11pm
It doesn't matter to any computer or electronics WHICH side you unhook first... the circuit is just a loop, so lifting one side is no different from the other.
The difference, is that when you have a negative ground still connected, and you loosen the nut on the positive post, and land the wrench against chassis or fender, you have a dead short across the battery, which causes substantial outgassing of hydrogen, and a really, really, really hot contact point where that current is flowing. This is the perfect recipie for a bomb, and you're still holding the wrench.
Always disconnect the grounded side first.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2015 at 6:32pm
I know firsthand about a battery bomb. It was winter time, D15 needed to be jumped to so I could spread some manure. Hooked up my Fathers '71 (??) Ford Bronco. Didn't know much about positive ground on the tractor. Battery blew up when I made the final connection to the Bronco--> thought I lost my thumb from the explosion. Never again..... I think the biggest battery pieces (plastic) were maybe 3 or so inches.
Be safe
This page was generated in 0.111 seconds.
