Headlight issue?
skeeters65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Topic: Headlight issue?
    Posted: 13 Aug 2015 at 9:25am
Hey guys I just picked up a B. That is still set up with a 6 volt system.
One of the headlights will come on and off if you tap the housing. And sometimes it comes on very dimly. What should I look at?
I don't understand this 6 volt system.
Thanks
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 9:27am
Sounds like a ground issue
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 10:15am
^^^ This.
The lamp is probably grounded through the mounting bracket. This is a common place where ground connections go whacky.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 10:47am
Normally that can be cleared up by removing the light and cleaning the rust off. There is a short wire inside that grounds the bulb that could not be making good contact with the housing. Take it apart and see what is going on. Learning time! Even us old duffers can't learn any younger.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skeeters65 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 6:03pm
Ok.
Time to dig in.
12v doesn't bother me. But this 6v stuff has me baffled.
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 10:03pm
Only difference between 12 and 6 volt, is the voltage. Everything still works the same. Must have power and ground for things to work. 1.5, 6, 8, 12, 24 volt don't matter.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 10:11pm
 could be filament in the bulb is bad and when you tap on it it bounces around and touches each other where it welds itself together and works, I would start cleaning and replace bulbs, or you could take out bulb and ohm through it
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 10:49pm
The reflector is supposed to ground to the case of the light, so the problem could be internal.
slip knot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote slip knot Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2015 at 11:30pm
On the old machines it usually the ground that goes bad. They use a case ground and every piece between the light and the battery ground has to be clean to complete the circuit. The best thing I've found is to run seperate grounds to each light. a easy check is to run a jumper wire from you battery ground to the light case. if it burns clean then you can assume the circuit is not complete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2015 at 6:36am
Connection problem whether ground or power. Sometimes the sockets get corrosion in them not allowing the bulb to make good contact. Other times it could be as simple as the grounds like the guys mentioned. Either way, easy fix! Don't let the 6V throw ya. Same as 12V cept' a little less voltage, and a little more amperage. Same principal applies.
If you pigtail connections are all corroded from age, we offer a nice wiring repair kit for the B,IB,C,CA model Tractors headlights.
Steve@B&B
This page was generated in 0.123 seconds.
