HD4 hydraulic 10-30w ? |
rentedhubbie ![]() Bronze Level ![]() Joined: 08 Jul 2011 Location: Seattle Wa area Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 14 Jul 2011 at 2:48pm |
I have a new to me AC HD4, It needs oils changed as they are "milk".
I have found the sticker that tells what goes where and what it is. But some of it is "RIB" = "read in book" and others confuses me,
The converter oil says use "A" type. I found hydraulic oil thats AW ISO 68 and ISO 100 in my shop. Is this the right stuff? what do I use?
next the hydraulic reservoir for the loader rams say use SAE 10-30w.
Its not hydraulic oil? Standard motor oil? Is this correct?
I have no numbers for filters or anything really.
Thanks, Anything you can do to help is really Great.
Todd, the rented hubbie
John(IN) ![]() Bronze Level ![]() ![]() Joined: 12 Sep 2009 Location: Franklin Points: 48 |
The type "A" is ATF. My books are not here but over at the location of my HD-4 or I could give you the spec for all the oils.
Edited by John(IN) - 14 Jul 2011 at 3:35pm |
Learn something every day!
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10777 |
Type A in torque converter, hyd fluid in hyd reservoir,I like Rotella 15-40 in engine, 90 wt gear oil in finals. Rollers use 90 weight with button fitting if not changed. HTH Tracy Martin
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41980 |
they called for 10/30 as the hyd oil has to be a good anti-foam and anti-wear property also.
mike l ![]() Bronze Level ![]() Joined: 04 Dec 2011 Points: 9 |
which oil in the 3 speed trans?
