HD3 engine swap? |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34627 |
Topic: HD3 engine swap?Posted: 02 Apr 2026 at 4:37am |
Got a salvage yard crawler with a bad engine. No injection system now and engine turns stiff. Anyone tried to put another engine into a HD3? What would be a good transplant engine to set in it if able to do so? Or does someone have an old Allis-Chalmers diesel 175 cube engine laying around that was taken out of HD3/ D15D that would be usable for donor parts? Here is a pic of crawler, blowing critter nests out of valve train area cuzz valve cover was sitting on the two studs. ![]() On market place, seen a Simpson SJ436E engine says 46 kw, and a Perkins 404...Also a 4 cylinder Mercedes OM616 2.4L Would that make the crawler run like a Cadillac? I might have to go hunt down a D15 160 cube engine and put in, probably be the easiest avenue to go. Sure would like to keep it diesel. Thanks, JC
rtwfarm
Joined: 26 Feb 2012 Location: nebraska Points: 1349 |
Posted: 02 Apr 2026 at 6:12am |
Got a couple here pm me
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1010 |
Posted: 02 Apr 2026 at 6:10pm |
I don't know how far you would go to hunt for an engine? A guy in Canada (in BC) swapped out a 175 diesel in his forklift and put in a Detroit 2-53. I know he was trying to get rid of the 175 but don't know the outcome. This is the guy:
He has a thread on the forum here, but the 'search function' is not doing anything for me. Eric
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 02 Apr 2026 at 10:43pm |
H4 AC used a 2200 AC engine that was also used in cotton pickers and few other units , it was a gas or diesel engine basic and turbo or natural aspirated in different applications
The Allis-Chalmers 2200 (often referenced as D2200) is a 4-cylinder turbocharged diesel engine utilized in various Allis-Chalmers agricultural and industrial applications, including tractors like the 6060, 6070, and 6080. These engines are known for their reliability but may require overhaul kits for maintenance https://www.google.com/search?q=Allis+Chalmers+2200+engine&rlz=1C1HKFL_enUS1206US1206&oq=Allis+Chalmers+2200+engine+&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCjE0MzQ1ajBqMTWoAgiwAgE&sourceid=chrome&ie=UTF-8 Edited by Coke-in-MN - 02 Apr 2026 at 10:48pm |
JC-WI
Posted: Yesterday at 4:16am |
That's a nice looking D2200 engine there in your link Coke, just wish it was closer instead of next to the Washington state border. ![]() |
JC-WI
Posted: Yesterday at 4:45am |
Eric B. I remember that AC forklift repower, found it. Link to the actual thread. google had several links to choose from. - http://www.google.com/search?client=firefox-b-1-d&q=Allis+Chalmers+FDX40+forklift+allischalmers.com some of the links shown Fellow is in canadia and need passport to get there so I don't think I will be going up there. Would be much easier to go see RTW.
Posted: Yesterday at 6:32am |
As far as I have been able to determine, the 2200 series engine (G-2200 gas/D-2200 diesel) was never turbo-charged. I had it in my head that there might have been a D-2400 that was turbocharged, but can't seem to come up with anything by googling. I thought I read that a D-2400 existed from a head gasket installation instructions sheet many years ago. The newer 1978 433-T and 433-TI engines were the first to be turbocharged and turbo/intercooled. They also were equipped with a Lanchester style engine balancer in the bottom of the engine so they could operate at 2500 RPM. These changes allowed the flywheel HP to reach the 100 flywheel HP mark where the D-2200 only ever got to 50-52 flywheel HP @ about 2000 RPM.
JC-WI
Posted: 20 hours 1 minutes ago at 12:00pm |
How much HP can a little HD3 handle?
The Buda D175 was 32 pto HP. Couldn't seem to find BHP on it I sure wouldn't want to go beyond that D2200's range 50- hp Looking
in a 1956 'The Tractor Field Book', under multi cylinder commercial
engines section, They listed Buda having 11 different gasoline power
units and same number of diesel units from the 4B-153 gas / 4-BD-153 diesel to the
6MO-970 gas / 8-DAS-1125 diesel. Nothing for Allis there, but Allis-Chalmers were listed under Tractor Engine Power Units specifications and only gas models. They were powering their construction equipment with Detroit Diesels prior acquisition of Buda. Here's a scanned image of the Buda specs from 1956.
Coke-in-MN
Posted: 14 hours 57 minutes ago at 5:04pm |
When I was down in Effingham was talking to a mechanic there , he said he had a couple D2200 engines and learned that engine handled a TURBO well as AC used it in their cotton pickers with a turbo - got it up to 85 HP rating in that use , said he worked over pump and few other things and had even more HP out of it .
So AC did use it TURBOED in product line |
Posted: 10 hours 41 minutes ago at 9:20pm |
Well, I do know that in that same 1978 ish time frame, when the K2/F2 combines got the 433-series turbo engines, the cotton harvesters did too. So, yes they would have been turbo'd from that time on. But, what about 1965 up until 1978 ?? He may have been referring to those engines as D-2200 from his old experiences but they may have been 433 engines.
