Hay Wagon Progress
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Topic: Hay Wagon Progress
    Posted: 13 Nov 2010 at 8:55pm
I finally got some time this afternoon to work on getting my wagon running gear apart.  The previous owner had welded the fron to the back with a short section of pipe.  They did a very thorough job of welding it.  I went through several cutting disks and grinding disks.  They even welded the outer tube to the inner pipe through a bolt hole.  THat was fun to drill out.
I found a layer of orange under the gray and gunk.  Any idea what brand this is?
I pulled the front wheels off to check the hunds.  The first one came off full of bearing rollers, the second had water in it.  I think I'll be buying four set of bearings, four seals, and a can or two of grease.  It had a combination of Timiken, KOYO, and NTN bearings and races.
As advertised -
Today -
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 9:23pm
Looks like a kory wagon.
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2010 at 11:16pm
Looks like the gears under a gravity wagon of ours and we were told they were Kory gears.
If fishing is a sport your looking at an athlete
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 7:21am
Thanks for the info guys!
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 8:50am
You may want to take your scrap steel from the tank frame and fabricate 4 bolster mounts from it that can be bolted into the 3 holes as seen on your wheel frames?
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 11:59am
That or some 3x3 angle iron I have in the metal pile.
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 1:32pm
Adam, sorry I didn't send you those pictures of my pivot on my running gear yet, but here they are.  The tube has a slot cut into it, and the bolt has a square washer cut to match, so that the rear tube can pivot 15-20 degrees in each direction.  Might not be the best design but gives you some ideas.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2010 at 7:00pm
Thanks Chuck - I'll have to figure something like that out.
Adam
