Hay Equipment
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 5:47am
Originally posted by allisbred allisbred wrote:
You forgot to mention the good— will suck up rained on hay and make it disappear! Lol. We still have a MC version which was a heavier unit and works very well under trees trimming hedge rows. Make sure to wear glasses!
If I ever buy a flail type mower again it will definitely be an M/C brand.
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2019 at 8:08am
Gary,
The mud is just were I run my tractor to reload the feeders.
The sheep have 15+ ac to run on that time a year.
The field in the back ground is were they will lamb at.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 7:28am
Originally posted by TimCNY TimCNY wrote:
AC7060IL, I almost pulled the trigger on a New Idea Cutditioner for $600 but then pretty much everything I read or was told is that it would be something I'd regret buying. Growing up, at least 2 neighbors used them, it left a mess of the stubble but wow did the hay dry faster than me using a New Holland or JD haybine and then tedding. I just found out the cutditioner is still for sale, price dropped to $500; what can you tell me? I'd rather hear real testimonies than hearsay and opinions. Same goes for anyone else, and I hope this isn't hijacking the thread. Thanks!
New Idea mfg 7’ & 9’ models. My 270 is an earlier chain drive. Later 272 had belt drive - Same with 290/292s. The cutditioner has its place. I probably cut/bale 20-30 acres of grass hay a year, consisting of waterways, road right-a-ways, hedgerow/fence borders, small farmsteads, & small fields(2-3acres).
CONS are: It’s slow cutting1st gear), 540pto so yes it’s a higher fuel usage, stubble cut is higher(4-5”), has 6” cupped flails that need sharpened/edged if it gets into rocks, limbs, & dirt, flail shaft could get bent if you’re not careful(stump,concrete??)
PROS are: Chain drive clutch allows flail rotor inertia to continue to rotate when pto is shut off during tight turns, excellent suck up of downed crop or old mow and optional fluffing/Tedder of rained-on hay. Simple crank height setting(no hydraulics), excellent hay drydown, stems get rubbed (conditioned?)by flail before cutting, higher stubble allows more air flow under cut hay & might allow quicker regrowth that seem to shade out weeds, trails(55mph)behind pickup truck, and quick to grease/lube.
I’m satisfied with it. I’ve been using it for 3 years. I use a angle grinder to lightly sharpen/edge the cup flails twice a year. My 7060(160hp) is overkill, but it’s cab AC is nice when extremely hot/humid. My platform JD3010 diesel (60hp?) is best for tighter places & handles it just fine with less fuel.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2019 at 11:29am
I first bought an old Hesston 1090 and it imploded after a year.  The reel shaft broke and some of the reel got caught in the conditioning rollers.  Total loss.  I bought an old ford hay rake and it fell apart after one season.  I bought an old Allis rake and it broke after 20 acres.   I basically have not had much luck buying cheap hay equipment.  I was lucky that I could borrow some equipment after these breakdowns to finish the job.  So, I gave up and went after better equipment.
I bought a New Holland 256 dolly wheel rake for $1,500.  Nice rake although, I need a v-rake to go faster.  Purchased a Kuhn 28GMD disc mower (does not have conditioning rollers).  I felt like the conditioning was not cutting down much on the drying time and the cost of the disk mower versus the disc mower conditioner was substantial.  I like the disc mower, simple, easy to transport, but it is a pain to hookup.  I think I paid around $6,000 for a 2013 model.  It is the newest thing I own.  I have an cherry JD 1950s 24T for small squares that cost $2,000.00.  It still has the original decals on it, so I probably paid a lot for a 24T.  However, in 3 years, it has probably missed about 20 bales, and it was mostly because the hay was just too wet.  I went 1,000 bales over 2 days and never missed a bale.  I bought an M&W 4590 round baler at first, but it was not fast enough and very hard to get a bale started in dry hay, so I sold it and moved to a JD 467 due to a forum member recommendation.  Love that baler and I can bale a 4x5 round every 4 minutes.  Paid $8,500.
I only have 4 cows now, so you might think all of this equipment is ridiculous, but my son and I did custom baling for about 10 customers and made good money to cost justify the better equipment.  Couldn't have done it with the old stuff.  Hay has skyrocketed here in Indiana and since I don't have many cows, I am selling my excess.
My take on your hay equipment topic based upon my experience, if you are only doing your hay, then you can buy some cheap stuff and hope it hangs together for a few years.  It will break and you can buy more cheap stuff every few years.  If you buy better equipment, then you can cost justify the higher expense by custom baling or selling your excess hay (sell some of your cows so you have excess) but you may not want to do that.  I couldn't take anymore breakdowns so I went with better equipment.
I am happy I sold most of the cows.  I made a lot more money off of hay this year than anything else and a lot less stress in the winter time.   Hay profit is far better than cattle profits right now.  You have gotten a lot of responses on this topic.  Good luck in whatever you do and if you go the old stuff route, hope you have better luck than me.
This page was generated in 2.204 seconds.
