Hard starting Perkins when warm.
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: Hard starting Perkins when warm.
    Posted: 28 May 2020 at 7:25pm
Working on a JCB 1550 backhoe with a turbo Perkins engine. I believe it's a Perkins 4.236.
I know this backhoe has seen lots of hours. The owner ran it out of diesel and could not get it started.
I replaced the lift pump and fuelshut off solenoid and blew out the fuel line coming from the tank. The line from the tank was severely plugged up. After bleeding the system, I still couldn't get it started. I found a can of ether in the cab, apparently the owner had been using it to try to start it.
I gave it a slight mist of ether and nothing. It took a direct, short shot into the intake before it would start. Once it started it ran great. However, it won't restart when hot. It will start no issues when it's cold, even without using the intake heater. But will not start hot.
I noticed when I shut it off hot and immediately try to restart, it hardly blows smoke. After about an hour, it will smoke while trying to start, but still will not start. Only after it's completely cold will it start.
Any ideas?
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2020 at 7:50pm
Lucas CAV pump?
Worn hydraulic head and rotor in the pump.
You are looking at a new pump.
A little CQB never hurt anybody.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2020 at 8:59pm
Or delivery valve not seating or broken spring.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 1:54pm
Originally posted by MattLF9 MattLF9 wrote:
Lucas CAV pump?
Yes! It is a Lucas CAV pump. Thank you for the reply. This really helps me to narrow it down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 1:55pm
Thanks Mack, this is where I'll start at. Hopefully it's something m minor like a broken spring.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2020 at 2:59pm
The head in the pump is likely shot. The CAV DPA seems to be the one most prone to wearing the head, compared to a Roosa DB. There is no delivery valve in a DPA.
