Grinding cranks on 301,s ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Grinding cranks on 301,s ?
    Posted: 10 Mar 2015 at 11:51am
Whats the deal with grinding cranks on the 301 diesel ? Seems that if they have been ground they break ? Is there a correct process to follow to help them not break ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2015 at 12:02pm
Don't know about 301's but 426's were picky that way.My shop manual has VERY specific remarks/instructions about journal radius when reground.I think most breaks were from too small a radius in the fillet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2015 at 12:14pm
The deal is this, if you don't know how to grind a H.D. diesel crankshaft, it will probably break sometime down the road. If your crankshaft grinderman (or woman) only grinds automotive cranks, he (or she) is probably ignorant as to how vitally important the radius of each journal is. It has to be dressed correctly. It cannot be ground to a square corner like many car cranks. Leaving the radius as "fat" as possible is very important. Also, if any journal has had a bearing burnout and blued the journal at all, the crankshafts hardness has been compromised and will surely break down the road, even tho it may have magnafluxed just fine. I have an old friend who was a dealer many years ago and had trouble with broken 301 cranks. I lived 60 miles away and never had a broken crank. We had different Machine Shops and that was the difference.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2015 at 5:44pm
Doc--- GRINDER WOMAN????????? Have we brought you out of the stone age (club woman, drag home by hair) and enlightened you into the politically correct gender neutral age???????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2015 at 7:02pm
I'm trying....it's difficult, but I am trying.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2015 at 9:10am
that applies to JD. Int. cranks also
