Grease zerks
cidrmakr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cidrmakr Quote  Post ReplyReply Direct Link To This Post Topic: Grease zerks
    Posted: 01 Mar 2012 at 6:53pm
I have an 1952 Allis CA.  Seem to recall that there was a grease zerk for the throw out bearing.  Can anyone confirm that there is or is not.  And, how do you get to it.....
Thanks, John
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:55pm
Should be under the torque tube, where the clutch inspection hole is.
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 7:04pm
The zerk is for the yoke not the bearing its self. The zerk is on the under side thru the inspection slot just back of the throw out bearing. I have taken several apart the the zerk was gone.
I thought I had a picture but couldn't find it just now.
