Governor and magneto
68mustang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 68mustang Quote  Post ReplyReply Direct Link To This Post Topic: Governor and magneto
    Posted: 15 May 2020 at 7:28am
1939 Wc , engine block replacement need to get familiar with installing the magneto and governor with out getting into trouble.
Any advice would be appreciated.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 7:33am
The Service manual for the tractor will give a detailed procedure for installing the governor then the magneto. If you don't have one and your working on it, you need a service manual. Any AGCO dealer should be able to get you one. Or make it simple, just call Sandy Lake.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 10:09am
The WC has a set screw on the crankshaft pulley that makes it easy to see where in the rotation it is. With the setscrew pointing straight down pistons 1 and 4 will be at TDC, and with it pointing straight up numbers 2 and 3 will be at TDC. The slot that the magneto mounts to should be horizontal in either one of these positions. It might be fun to see how it is prior to disassembly. If it is set to fire early then hand cranking could be dangerous. You will notice that the governor gear rotates at crankshaft speed so every 180 degrees it is horizontal again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 10:20am
This is why you need the Governor mag drive slot horizontal at the times mentioned in my last reply, and on normal mags this is not adjustable. Then as soon as the RPMs are high enough the impulse coupler pawls pull in and the spark advances to 30 degrees BTC.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2020 at 7:16pm
Not sure about the WD but my WC governor housing has large hole to the top side of the coupling section and wide rectangular opening underneath also. Just seemed curious. I cleaned out 80 years worth of sludge to get it ready to paint.
