Govenor Spring Help - wd45
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Govenor Spring Help - wd45
    Posted: 22 Nov 2011 at 8:57pm
I have a wd45 I am rebuilding and would like to get a few more rpm's out of it.  I have read I could change the govenor spring to a D17 or a 175 spring.  What would give me the most rpm's thanks!
Edited by Brampton 02 gt - 22 Nov 2011 at 9:00pm
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:08pm
if you are just looking for the most rpms, the 175 will do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:09pm
D17 spring approx 2000 rpm...170-175 spring approx 1800 rpms....all are based on a properly adjusted/synchronized governor....improper adjustment yields different rpms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:11pm
Dr. Allis is there an old post of yours explaing adjustment you could kindly direct me to
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:20pm
I wont argue with you... but my 45 runs 2200 rpms with the 175 spring. never tried a 17 spring.
Jeff B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 9:51pm
High Idle rpm is not governed rpm. Full load rpm on a d17 is 1650 and 1800 on 170 175 and 1400 on a wd45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 7:31pm
Is the spring that hard to change?  It looks like it would be a pain once the rad goes in.  I ordered a D17 spring - maybe I should have got the 175 spring.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 9:16pm
the 175 spring is available at any agco dealer,part #70226785.about $40.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2011 at 9:28pm
I ordered one from AGCO last year. it comes as spring and plunger. the AGCO catalog has 1400, 1600, and 1800. listed. takes about 1/2 hour to change with the raditor  and hood still installed. I used a needle nose visegrip to hook the forward end. there is not much room.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:28am
Our WC with a 45 engine and 17 spring runs just a tick over 2000 rpm and idles real nice at about 700 rpm.
This page was generated in 0.035 seconds.
