Good News, Bad news
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: Good News, Bad news
    Posted: 30 Jul 2012 at 7:21pm
I have a "C" that gets water ( lots of water) in the oil. Could be freeze plugs , head gasket, or O rings. Decided to pull the pan today and then fill the radiator. Did that and the water runs down the front wall of the block, good news its not the O rings, bad news I twisted off one of the pan bolts. Got confused as to left and right since the bolt is upside down. So now it is either the freeze plugs or head gasket.
Question where and how does the oil get from the top of the engine to the bottom, is it at the front of the engine. Thanks for the help.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 7:34pm
Hope your right. It may be a cracked liner however.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 7:43pm
Remove the tap-its cover and look at the freeze plugs.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 7:43pm
pull the valve cover and look at the 3 plugs under the cam shaft next..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 2:18pm
Good news it was a freeze plug, looks like someone put a screwdriver thru it.Tongue Will have the part tomorrow from Sandy Lake.
