Gleaner N5 can't get clean sample in corn
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner N5 can't get clean sample in corn
    Posted: 15 Nov 2016 at 5:37pm
Having a lot of issues trying to get a clean corn sample on my 85 N5, Concave set to 3/4" Air setting is 7. Chaffer opening has been set from 1/2" to 5/8" no difference, bottom sieve quite open, still getting lots of fotter in the bin, loss is low, its like the fan is not working correctly but i can feel the air blast from behind, anything else I can try? oh and its got brand new accelerator rolls.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:59pm
Need a little more info. Head size,speed, etc. If fodder, what happens when you close the Chaffer? Air is a big deal, is the fan clean?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:53pm
Is this your first corn harvest with this machine??
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:45pm
Some varieties combine cleaner than others.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:45pm
You haven't been too specific as to how far the bottom sieve is open, ,but you sort of imply that it's open quite a ways. Close it down until you get a clean sample. Darrel
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 10:00pm
 Is there a shield out of place or rusted though? Climb over the shoe and look at the tin in front. 2 years ago we had this issue in our R-62. If its open in front of the shoe trash will fall right on the clean grain auger. Only takes 5 mins to check.
Thanks & God Bless
Dennis
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 11:48pm
it sounds like the sieve is open too far. Close it down a little.
Also, make sure ALL shields are in place, including the front one beside the feederhouse. the transverse rotary Gleaner moves a massive amount of air and can suck trash into the fan if all shields are not in place.
Refer to the operators manual for the location of the shields.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
