Gleaner L rear wheel pattern
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner L rear wheel pattern
    Posted: 15 Dec 2016 at 6:34pm
A guy has a set of 6 lug wheels he said is off an L Gleaner rear axle.   Will these fit any Allis tractors?
Life is simpler when you plow around the stump.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 6:46pm
they should fit the 6 lug tractor front ends' 15' or 16' inch'' wheels ok..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 8:42pm
I thought 6 lug hubs on an L was nuts but parts book shows it to be so...
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 9:30pm
I have an L with 6 lug rears. Its the standard 6 bolt implement pattern.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2016 at 10:21pm
and will fit some wagons too....
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 11:04am
Are you talking L or L2. Because all the L2/L3s we have had , have the 8 bolt wheels on them.  We put our turf tires off of our 7080 one year to hold the rear up in the mud. and yes they are the same bolt pattern
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 11:31am
Advertised as L and 6 lug.  Thats all I know at this time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 11:37am
The bolt pattern will be the same as a 185, 200, D19 and the like. Pending the size and back spacing of the rim it may or may not fit even though the bolt pattern is the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 11:41am
pretty much universal. I've used the wheels off the back of all my combines somewhere on other equipment if I needed to save time. as long as they match on how many bolt holes there are, 5, 6, 8. I've put the wheels and tires off my IH combines onto my 7010 and 7080, and they fit perfect. use what you have! them 6 bolt rims will even fit the older Chevy pickups if you are stranded...just don't drive very fast, but they'll get you to the tire store! I have one 8 bolt rim and tire on my backhoe right now off a wagon. and have used the front 5 bolt off my WD and put on the AC field cultivator. and have seen a lot of fancy 6 bolt mag and crome wheels mounted on the WD's, WD45's, and the 100 series tractors
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 11:57am
they will fit the 190 but you have to run them dished out as the back spacing wont clear.  i have a set on my 190xt running 10.00-16
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2016 at 4:14pm
I learned something today.  Even our F3 has 8 bolt wheels on back.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 12:43am
On the L, starting in 75 or 76, 8 lug became optional, but 6 lug was still standard at least through 77.
On the F series, 8 lug became available on the F2s, but 6 lug was still standard. I dont recall seeing a F3 with anything but 8 lug.
On both the 6 and 8 lug, they are both standard ag patterns, fully interchangeable, all depending on if the backspacing of the wheel is compatable with the application.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
This page was generated in 0.067 seconds.
