Gleaner K Concave Tool |
Author | |||
KGleanerIA ![]() Bronze Level ![]() Joined: 22 Aug 2017 Location: Northeast IA Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Sep 2017 at 8:20pm |
Hi,
How can I make a tool to open the concave door on a gleaner K? I was told it looks like a tire spoon. What is the spoon part for? Do you use the tool to open and close the door? Thank you
Sponsored Links | |||
Dans 7080 ![]() Orange Level ![]() Joined: 05 Feb 2010 Points: 1146 |
Any model that has one will be the same. It would be easier to check a junkyard for one. It is similar to a tire spoon but it has a loop welded to it. The spoon part is for prying the door open and closed. The loop will engage the latch.
Edited by Dans 7080 - 13 Sep 2017 at 8:37pm |
When someone tells you Nothings Impossible, Tell them to slam a revolving door
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
What Dan said
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
I remember using one, it was on an "E" mid 60's. Don't recall measurements though!
I was working on the light ground, and opened/closed the door a number of times. A steel rod about 16 inches long with an inch long piece of tubing to slip over the latch lever, spoon/flat like a screwdriver(large) both on same end of tool, stored on? oops, forgot. Two brackets with holes where tool could slip through, I think on one of the elevator thingy's, close to the steps. Here I am rambling on. A tire lug wrench a an end of tubing welded to it will work
Now that Joe mentioned the 2 brackets, are you sure it is not hanging on the clean grain elevator about eye level ??
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
I always used a 2 ft long conduit pipe, unlatched it and the door would fall open
oh...and don't sit/lay under where the door opens....
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8456 |
X2!! Can't stress that enough!! I learned that the hard way. If you can, always park the combine perpendicular to the wind, and stay upwind from the door. When you go to shut the door, you can lay on your back and use your legs to do most of the work.
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
And be careful when using your leg to close the door. Heard of it slipping off a foot and having the lever right back in between the legs. Don't want to try that. |
That's why I usually lay offset and use my outside leg.
Maker sure you put tool on lug the right direction or you will bend or break lug. MACK
