Gleaner header reel/ hydraulic advice needed
Kyle(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kyle(MN) Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner header reel/ hydraulic advice needed
    Posted: 02 Oct 2017 at 10:54pm
This might be a more general hydraulic question, but...
I've got a '68 Gleaner G with a grain head and reel on it for the first time after a couple years of a corn header (soybeans this year). I've had the up/down and variable speed for the reel working a few weeks ago, but what I thought was a small leak in a hydraulic hose to the header turned into a big leak on my trial run last week, so I couldn't get the reel to lower, and there was no variable speed.
I replaced the two hydraulic hoses from the combine to the header, and used the old couplings to the header, which seemed OK (?). I tried it tonight; the reel lifts and the variable speed works, but I cannot get the reel to lower. I've bled the lines. Still- can't get the reel to lower (without opening up the lines and releasing fluid, that is).
I'm stumped- does anyone have any advice for me?
Thanks for any help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 8:27am
you still have air in the lines
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 8:30am
I had that problem on my "G" once. I messed up and just bled the one side, after that it would go down but the one side would go down first, then the other side. so I should have done both sides a little at a time I think!
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 8:36am
Have someone watch the hydraulic valve and make sure the linkage is moving it all the way. When the linkage gets to much play it wont activate the valve
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 9:10am
Linkage issue and throttle the engine up all the way.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 1:17pm
Sometimes that linkage can sieze up so when you pull up push down or go back and forth it moves both linkages instead of the correct one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kyle(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 9:48pm
Thank you all so much for the input. I'm going to concentrate on trying to bleed the system better. I -think- my linkage to the pump is Ok.
