Gleaner F2 |
Josh N
Joined: 01 Feb 2019 Location: Roaring spring Points: 56 |
Topic: Gleaner F2Posted: 05 Oct 2019 at 9:24pm |
What heads fit on the gleaner F2 ? Will a 313 or 315 fit or just models before them? And does anyone have a flex head to fit my f2 in or close to pa
MACK
Posted: 05 Oct 2019 at 9:43pm |
JD 216- 915 with a little work
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 06 Oct 2019 at 6:05am |
Mack, in your opinion, what was the most "challenging" issue that came up during the modifications to make the 2 units work? How did you get the reel to run on the green head, aren't they run with a pump ? Thanks
MACK
Posted: 06 Oct 2019 at 6:30am |
Mounted a hydraulic pump above right drive shaft. Used a flow control valve with control cable to cab. MACK
Posted: 06 Oct 2019 at 8:56am |
Josh, is your F-2 combine equipped with auto-header height control ??? That feature was NOT necessarily standard equipment.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7570 |
Posted: 06 Oct 2019 at 9:06am |
Our local Allis dealer used to have a kit available to add auto header height control to older F and F2s. In which case the 313 head could be used to work with it.
Josh N
Posted: 06 Oct 2019 at 9:53am |
Yes dr. It has the valve on right side of cab. Just bought the machine. Didn’t get it home yet. Has a 13 ft ridged head. Like to find a flex head and get the auto control working. Kinda new to me
MACK
Posted: 06 Oct 2019 at 8:27pm |
Best to get a head with electric header control, and put electric valve on combine. You will hate the oil heating hydraulic control even with helper springs. MACK
Josh N
Posted: 06 Oct 2019 at 9:07pm |
Mack which model gleaner head had the electric header control?
Posted: 06 Oct 2019 at 9:22pm |
300 series came with the electric height control system, but that doesn't mean there isn't an older 200 series head that has been converted to electric. You have to add-on and electric control valve system to the combine if you choose to go that way with the header.
MACK
Posted: 07 Oct 2019 at 7:44am |
F3 and up. There was a kit to put electric valve on older combines. MAck
