Gleaner F2 Brakes
Johnwilson_osf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F2 Brakes
    Posted: 28 Jun 2015 at 9:20pm
Greetings,
I am likely to have to repair the steering brakes on my F2.  I topped off the fund to the brake reservoirs, but I still have no stopping ability in the Left side, as I am losing fluid.  I power washed the entire front end, and see no leaks on the brake lines, so I can only assume I am leaking in the brake assembly.  Has anyone had theirs apart?  What is the likelihood of an internal leak?
How does the system work?
Thank you,
John
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 10:02pm
It is the brake cylinder inside the brake housing that needs to be rebuilt.  All the pads will need to be cleaned of all oil residue as well.
My dad had to do that many times over the years on his K and F later on.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 10:10pm
Take the adjusting nut off the brake cylinder, then remove four bolts and lift cylinder. It will need new piston and two orings.
  If it has leaked for a long time you will have to clean up band and drum.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnwilson_osf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 5:55am
Thanks DSeries and Mack.  Sounds simple enough.
John
