Gleaner F price???
Grader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F price???
    Posted: 21 Dec 2015 at 7:31pm
I've got my eye on a couple gleaner f combines but before I go try to make an offer I was curious as to what others opinions were on value. One is a early f that has 6 cyl diesel and gear drive. It's probably a parts machine but i like to revive these old machines. Also has no header. Any input would be appreciated.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 7:34pm
If it's a machine in "parts" condition, I would start at scrap value.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 7:38pm
Scrap is so dang low that I feel I might insult some people. But that's why I'm asking for advice because I'm not sure.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 7:58pm
Trying to find a decent header (without the combine) would be the hardest part.  It's hard to put a value on the combine when you do not know what it is going to need.  What shape is it in now?  Tires, belts, sheet metal missing/banged up, does the engine run good?  Things like this can add up real quick.
If the diesel engine runs well, I would offer $1000 (that is the most valuable part of the machine).  Are you planning to use the combine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 8:14pm
I've got an F and F2 both diesel and hydro. I could use it running or not as I cut 50,000 pounds of clean fescue each year so parts are always nice to have on hand.
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2015 at 10:25pm
I don't know your region- stuff up here is a little more expensive. But, if it runs and moves, yet is a parts machine, I'd say $2000 tops out here- probably less.
If it's field ready, maybe $2500. There's not much demand for them out here....
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 7:19am
Think I gave $800 for mine last year at a retirement auction. 1976 model, 292 eng. gear drive and came with 4 row black head. It's been a good machine so far.
combinechris View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote combinechris Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2015 at 8:21am
Here where I am at gleaner f or f2 are around $1000 on up
35 combines and 15 forage harvesters. mostly allis combines and equipment.WTB 2 row cornhead for a 90
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grader Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 5:10pm
I just found out the same guy has an f3 with a bad engine and has 15ft ridid too. What's the market for an f3 in this condition?
mo 180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mo 180 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 9:07pm
About a month ago a F2 diesel hydro sold in west central Missouri for around $2,000 with 4 row 30 black head. No Platforms. 2 Fs parts machines under $100 each less motors.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2016 at 10:12pm
I have a 13' bean head for F2 that I would sell.   MACK
This page was generated in 0.230 seconds.
