Gleaner e |
Steve g ![]() Bronze Level ![]() Joined: 17 Jun 2017 Location: Cen.ohio Points: 101 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jun 2020 at 7:15pm |
Just picked up a E with a 2 row head.
I see 4 pins that what I believe hold the head on . Large drive belt is off. Am I missing anything else to take head off combine. I see a chain on a sprocket left side next to drive belt does that chain have to come off also. |
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4543 |
The four pins are spring loaded. Push (hammer) them in and move into the slot to hold them in.
Took two grain heads off last week.
Release two bottom pins, let head down until theirs 2 inch gap at bottom. Set jacks or blocks on each side. Release top pins and back up. MACK
im4racin ![]() Orange Level ![]() Joined: 12 Jun 2017 Location: Garrison ND Points: 1063 |
Yes that chain has to come off. The tool on clean grain elevator has a dimple in the end to push the 4 wedge pins in. When you get them pushed in slide down in the slot to hold them in the released position. What is the serial number of your E?
Thanks for the replies not sure of serial number yet been sitting long time at this old boys farm. Got to get it hauled home. Jacked it up out of the ground last week only 1 flat rear tire
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
I have an E with both heads---also got a book with it for an E III but looks like same machine almost.
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
E III is same as a K except for the engine.
My late E(E19600) is closer to an E3 than an early E.
Pulled top radiator hose very green antifreeze in stat housing and drain plug in radiator came out and again very green water shot out . Will it start
Hard to say. One of mine was stored inside all but the last 3 years before I got it. It had stuck valves. Bought an f that was in the pasture for 25 and it started and drove off trailer.
Going to help a friend get a 6600 gas that has been in the weeds for 10 years tomorrow. Hope for the best as he wants to take it to the field this fall! |
