Gleaner E carb question
olivetroad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote olivetroad Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner E carb question
    Posted: 03 Dec 2019 at 3:16pm
Is a carb off a Gleaner E the same as a D-17?
What is the recommended setting of the needle valve?  How many turns from bottomed out in the seat should it be backed out to roughly start with?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 5:10pm
olivetroad,
My guess would be a turn and a half? That seems about the norm. We will see what the experts say. I should know this, but it may have slipped out of my old head or never got shoved in there.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 8:53pm
Throttle shaft is different. Set the float to where it is parallel with top surface of carburetor.        MACK
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2019 at 9:00pm
"needle valve" is too broad a term: There is the needle valve that the float moves up and down, the needle adjustment for idle air/fuel mixture, also the needle adjustment for high idle gas/air mixture.
Adjust the float like MACK said, the low idle screw on top of carb should be turned out 1/2 to 3/4 of a turn off the seat. (Out means more air)
The high idle needle adjustment screw likes to be 2 1/2 to 3 1/2 turns out from the seat. (out means more gas)
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote olivetroad Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 8:49am
Thats exactly what I was looking for - Thank you!
