Gleaner E 3 row Corn Head ?? |
allisguy.11
Joined: 02 Oct 2012 Location: Perry, Ny Points: 577 |
Topic: Gleaner E 3 row Corn Head ??Posted: 05 Aug 2016 at 2:14pm |
Got small grains done for the summer so I am wanting to put the new corn head I found on my E. Its in really nice shape and I'm excited about it. My question is this: old timers say they would put heavier lift cylinders on the feederhouse and maybe even an accumulator to withstand the weight and shock with the heavier 3 row head. Apparently didn't need them on the 238... is this true? kinda doubt i will be able to find this setup so my next question is
will my smaller factory cylinders work? thanks in advance
nickia
Joined: 11 Sep 2009 Location: alden iowa Points: 792 |
Posted: 05 Aug 2016 at 5:49pm |
should work fine i have a 3 30 on mine
MACK
Posted: 05 Aug 2016 at 9:56pm |
If you have the small cylinders , it will work until oil gets hot. MACK
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 05 Aug 2016 at 11:00pm |
ran a 330 on my "K" just fine for years. think it weighed about the same as the 13 ft header I used on it.
michiganmarty
Joined: 19 Feb 2012 Location: central mi Points: 69 |
Posted: 06 Aug 2016 at 7:01am |
the latter E's had a higher pressure relief valve, but we ran one for years on the lower pressure with small cylinders. it will make the back end light though.
allisguy.11
Posted: 06 Aug 2016 at 7:38am |
okay. planning on putting some wheel weights in the back and if needed ill make a little suitcase weight bracket on the rear axle. thanks for the replies! we will see what happens |
