Gleaner A
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner A
    Posted: 16 Jul 2017 at 9:07pm
I am trying to find specs on Glaener A combine. It has a 230 Buda gas in it. Tried searching the forum and online but not much luck.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 9:45pm
What all do you need to know? Engine specs? Separating/cleaning specs? etc?
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 10:19pm
Looking for engine specs, weight, height.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 10:57pm
If some one has a D19 , out side specks are the same along with A,A2,C,C2,and early F. MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 6:13am
Hay Brian..
Get ahold of Ron Buttrum, here in Dundas. I gave him mine last year so I know he has the manual on it ! His son Scott's online here.....not too often though.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 9:30am
I checked Norm Swinfords book and I found out that the 230 Buda is 76 HP. Still trying to find out the weight and height. It has a cab on it and 18.4x26 tires.
Bruce(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 11:46am
This is from the operators book, serial no.26001 and up
Earlier machines are a little different
This is for 13x26 tires and no cab
Edited by Bruce(IA) - 17 Jul 2017 at 12:01pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 10:28pm
I thought you wanted engine specs and engine weight. That is what your post said.MACK
This page was generated in 0.152 seconds.
