Getting LED lights to flash? |
   JayIN
      Quote   Reply
     Topic: Getting LED lights to flash?Posted: 30 Mar 2019 at 11:28am  |
   I bought  a 12v LED magnetic towing light kit from Rural King to put on a wagon/hayride project I am working on. (too wet to do anything else)  What would it take to get them to flash? I think I heard somewhere that they dont draw enough current for a regular flasher. Also--- My WD45 is still 6 volt. It has that kinda rare implement plug-in by the back work light. I would like to use that if possible. Can I run these on 6volts? I'm not to bright when it comes to electrical stuff.....
  Any help is appreciated.  |
   CrestonM
   Joined: 08 Sep 2014 Location: Oklahoma Points: 8457  |
      Quote   Reply
     Posted: 30 Mar 2019 at 12:24pm |
 I'm not one to advise on electrical things, but does anyone have a photo of this plug-in? It's something new to me.
   Dakota Dave
      Quote   Reply
     Posted: 30 Mar 2019 at 12:33pm |
   You cant run them on 6 volt.on a regular flasher they dont draw enough you need to change to a solid state flasher for leds your best bet is to get the self contained towing flasher.thats what i did for moving the fish house. A set of batteries has lasted scouple years. I just turn them on before hitting the road and turn them off when done. I think they were less than 20 a pair at harbor frieght. The magnet holds them on at 65 mph
   DougS
      Quote   Reply
     Posted: 30 Mar 2019 at 1:31pm |
   You'd need an LED flasher, no matter the configuration. As Dave said, LEDs draw very little current. You could charge up a 12 volt car battery and put it in a battery box on the wagon and it would last for hours and hours before needing recharging.
  Edited by DougS - 30 Mar 2019 at 1:31pm  |
   wide
   Joined: 29 Dec 2018 Location: north iowa Points: 169  |
      Quote   Reply
     Posted: 30 Mar 2019 at 3:46pm |
   Usually a flasher is used for 2 LED lights.
  Front and rear turn signals. If your lights have more than 2 LEDs or you connect an extra set of lights, it might draw enough to work with a regular flasher. You won't be able to use a 12 volt LED setup with 6 volts, and I'm warning you now, don't ever try using a 6 volt LED setup with 12 volts. ,... Unless it's the forth of July and everyone is standing back. Overvoltage an old incandescent light and it burns out,.. not so with an LED.  |
   MACK
      Quote   Reply
     Posted: 30 Mar 2019 at 10:23pm |
   6 volt will light a 12 volt led light, but won't work on 6 volt + ground.       MACK
   Burgie
   Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192  |
      Quote   Reply
     Posted: 31 Mar 2019 at 6:04am |
You can put a non LED light in line with the LED`s and it will give you enough draw.
     "Burgie"
   JayIN
      Quote   Reply
     Posted: 31 Mar 2019 at 6:27am |
   Ok. thanks guys. I ordered a flasher from Advance Auto. $12. Daaaaaang!Maybe it will stop raining someday.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
