Hd6g info/question about hydraulic track adjus
dav68camaro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dav68camaro Quote  Post ReplyReply Direct Link To This Post Topic: Hd6g info/question about hydraulic track adjus
    Posted: 26 Sep 2012 at 11:35pm
I have a 1966 hd6g loader that is in rather good mechanical condition but does have a few issues I am slowly trying to fix as I use the loader to build a 1500 ft road and clear a building site for us to build on all in heavy timber.  It has worked great so far and I have put 60-70 hours on it since I purchased it early this year.   We are doing almost all the work ourselves on evenings and weekends so it slow going but we are saving a lot of money and learning a lot as we go.
Issues I have
Left side track has popped off 3 times in this 60-70 hrs of use.  It is currently off and I am attempting to get it back on but this is the first time it has came completely off the front idler and part of the lower rollers.  I have released the tension on the hydraulic adjusters and found the adjuster rod was not seated in the spring pocket and the rod does not want to line up with the pocket. It is about an inch below and to the side of the pocket.   I haven't had a lot of time to work on it yet as I only have 30 minutes to an hour each evening before dark to work on it after work.   Also as my rails are worn and stretched out and my idler is almost all the way out  but when I went to release the tension I found the adjuster housing was hitting the cross brace and appeared to be fully retracted and bottomed out.  The rod will retract further inside the adjuster but as it is not touching the pocket  and the adjuster appears bottomed out against the frame bracing this does not help.  In diagram below the area in red on the adjuster is hitting the outside of the box welded on the frame that the adjuster rod goes into before entering the spring pocket.  It doesn't seem correct to me as I would think the frame/adjuster would have more than the 1-2 inches adjustment before pushing the idler off the end of the frame.
6000 series engine with muffler rusted out top and bottom.  When I get time I will try cutting the center section out and welding a y pipe in between as I have seen others do if this does not work I will try making my own manifold. not a major issue just gets annoying with the exhaust in your face all day.
Rail are worn out to the point the bottoms section is almost worn through.  Trying to get the building project done with what I have as the wife has me on a deadline to get everything done by the end of the year.  Have like new rails to install but don't have the time until I get us moved in.  Sprocket shows minimal wear as do the pads that are near full spec.  Not sure what operation would wear the rails but not the pads or sprockets.  I do know it was a small towns machine for most of its life and was used for packing and not pushing or digging for many years.
Rollers are shot but I have found enough good ones to replace all of them with like new rollers for cheap.  Will change out when I put the new rails on. After this my undercarriage will measure out to 90-95% new and hopefully the old loader will last  another 50 years as I try to take care of my equipment.
I have already built a basic brush cab, fully serviced unit, replaced several bad hydraulic lines, batteries and all new 4/0 cables,  Left clutches and brake lining, u-joints, and many little adjustments and fixes to bring it back into specs per the operators manual.  Still looking for a digital copy or cheap hard copy of a service manual for a 20000+Sn HD6 and any suggestions to help cut final grade for road and building site with loader and tooth bucket(at least in the near future as the teeth and adapters just arrived)
Thanks for all the help and information I have already received from the site and will add a few pictures when I get them uploaded.
David
Edited by dav68camaro - 26 Sep 2012 at 11:42pm
ac_sd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 9:32pm
I have a good exhaust manifold/muffler off an Early HD-6 with 344 engine, but should fit yours also if you are interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac_sd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2012 at 9:33pm
My Son just noticed the 68camaro   "nice car".......
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 11:00am
When the track comes off you have an alignment problem. If the front idler is at the end of the truck frame and your track adjusters are at maximum, your pins and bushings are at the end of their wear limits. If as you say the sprockets are good you will wear them quickly with a stretched chain. If you replace the chain it will help keep the track from jumping off. If you can't change it now, perhaps you have time to fix the front idler. Check the idler bracket where it slides on the truck frame. Add shims under the track idler slide bars. Most important check that the idler is aligned and that the idler bearing is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dav68camaro Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 11:32am
I got the track back on thursday night as I got off work early and had a few hours to spend working on it.  A couple come alongs and bottle jack did the trick  once I got all the crap out from around the track.  I did check the bearing while the track was off and it was nice and smooth with no play.  I have the loader back at the house now so I will check the alignment and try and get the track adjuster fully functioning before I put it back to work.
The idler does slide smoothly on the slides. My rails are stretched well beyond the limits and I have been monitoring the rear sprockets for wear as they are in excellent shape.
My question about the adjuster hitting the frame is more for when I put my new rails on that are much tighter.  Currently it appears I can only move my front idlers back 2-3 inches total from the end of the frame before the adjuster housing marked in red on the dwg above bottoms out in the holder welded to the frame.  Is this normal as I was thinking It should have alot more adjustment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 12:01pm
My 1956 HD6G has mechanical adjusters with 4 inches of adjustment. My recently aquired HD6G has the mechanical adjusters adjusted out 8 inches. The previous owner welded an extra length of screw thread on the adjuster. I can see between the grousers. I am using the machine and not yet thrown the track. I am planning to replace the chain next year but for now I have dirt to move. I will be putting on full grousers because I will be pulling out tree stumps with it. It is an accepted option and I know it is harder on the undercarage.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 12:12pm
Remember that few inches of movement is double the amount , so 3" of movement is equal to 6" of take up on the track.  That would be like a full link of the chain. Remember a 1/8" of wear in each pin and bushing X 39 links = 4.875 of wear for full track = 2.375 or so movement of the front idler.
 So a little wear compounds but a small adjustment takes up a lot of slack .
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2012 at 5:58pm
If your hydraulic track adjuster is at maximum extension and your track is still too loose you can put spacers between the idler bracket and the yoke. You can also use this trick if the idler is out of alignment. This will allow you to use the machine until you have time to fix it correctly.
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2012 at 3:01am
If the carrier roller(s) are bracket mounted you can put a spacer plate under that too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dav68camaro Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2012 at 11:12pm
Thanks for all the help and ideas so far.  My adjusters will tension the track but bleed down in 5-10 minutes as the seals are bad.  I have the seals already just trying to get the work done before I pull the undercarriage apart and fix it all at the same time.  I did find my left idler not running true with the frame.  This appears to be caused by the adjuster holding it as the adjuster rod is not in line with the pocket.  I have cleaned everything out and got everything freed up and added a shim between the idler and adjuster on the inside.  I am also going to make a couple more shims to put between the idler and adjuster on both sides to tighten the chain up.  Hoping to have it all done by the weekend so I can get the road and building site finished up.  Also I want to try out the new teeth and adapters I am in the middle of welding onto my bucket hoping they will make it a little easier to cut down the high spots and dig in the hard MO clay we have.
This page was generated in 0.201 seconds.
