200 hydraulic equalization hose install
INAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Topic: 200 hydraulic equalization hose install
    Posted: 22 Jun 2024 at 1:13pm
Decided to try to "temporarily " install a hydraulic equalization hose to get me by until winter project time. What are you guys using for the bottom drain plug, standard 1/2 inch elbow doesn't thread in. Believe it is an npt? fitting? Been to red and green dealers, 2 supply stores and an auto parts with nothing but puzzled looks. Any help appreciated. TIA
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 2:41pm
Id weld a merchant coupling to the head if the plug and drill a hole through the plug. That would give you tapered pipe thread to screw a fitting in
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 3:01pm
That drain plug that points straight down from the belly and takes a 7/8" is 1/2" pipe thread. You should be more concerned about the drain plug behind the battery box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote INAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 4:06pm
The one behind the battery was simple, 1/2 90 degree elbow and some tape. One underneath is a course thread that I can't get ma5ched up
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 4:35pm
drill a hole thru the plug and tap for pipe thread.... Does not have to be a BIG hose..
it is probably a BOLT thread..or SAE plug size ... If you measured with a MIKE and get the thread pitch, they do sell adaptor plugs.
Edited by steve(ill) - 22 Jun 2024 at 4:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2024 at 4:46pm
im not saying it is a -12 fitting ... but if the OD of the plug is 1- 1/16 inch ... then something like this should fit.. ( 12 threads per inch)..
