RC tractor info
Nathan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan Quote  Post ReplyReply Direct Link To This Post Topic: RC tractor info
    Posted: 09 May 2017 at 9:09pm
I can't find my notes on the rc. What if any parts were specific to the rc? I seem to remember something with the front end and the rear wheel centers. Thanks guys.
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 9:30pm
The front wheels were a 15" with a WC bolt pattern. Some claim the rear centers had one mouse hole and the WC's had 2. I don't buy into that because I know of an original one owner RC that has the same centers as the WC. RC has a plate on the frame in front of the engine to cover the extra space. RC frame may have a notch in the drivers side frame rail, can't remember?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 9:51pm
I have seen a few with just the 1 mouse hole in the rear centers. I believe the story was the early RC's got 1 mouse hole, then when they put 2 mouse holes on the WC's, they changed them on the RC as well.
Maybe Tom Foss will post a pic of his. It's that way I believe.
Also, I think the differential was geared lower to give it more pulling power with the smaller hp engine.
Edited by CrestonM - 09 May 2017 at 9:54pm
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 10:48pm
And the rear end pinion gear lacked a straddle mount bearing....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 11:15pm
The RC had a lot of parts that were special to that model. Grille shell shorter, notched frame rails, different gear ratio, special motor mounts for the B motor in the WC frame, fuel tank, along with a few other small differences.   HTH
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 7:23am
clutch disc is the B diameter but has the wc sized spline
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 2:43pm
The flywheel is one of it's own.
This page was generated in 0.124 seconds.
