Reading a 8030 serial number
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Topic: Reading a 8030 serial number
    Posted: 01 Mar 2020 at 2:16pm
Having a little trouble breaking this one down, I'm not sure what the format is supposed to be and the sticker on the frame rail is worn off. What year of unit do I have? And which numbers are the serial? I thought it should be four numbers. Pic attached...I hope.
Matt
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 2:26pm
2472 last two maybe for 1984. First time i have ever seen that
Edited by Daehler - 01 Mar 2020 at 2:27pm
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 3:03pm
Tractor Data Info
1981: 1001
1982: 1009
1983: 2093
1984: 2701
1985: 3146
Final: 3328
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 4:39pm
Looks to me like mid year 1983.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 5:54pm
Ok thanks, I was thinking mid 83 too but wondered why it would say 84 then, or 84 at all since it should be four digits.
Has the look of a 'last one on a Friday' job by the numbers' stamper
Matt
Edited by Northern Hoser - 01 Mar 2020 at 5:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 6:08pm
Maybe its a phone number Lol
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 6:05am
Serial # Is Stamped in The Rear Housing  Above pto Shield
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 3:06pm
   After seeing your number I had to check mine out. It has a F between 8030 and the serial number but no other numbers. The F probably means power director tractor
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 3:18pm
I thought F meant front wheel assist
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 6:44pm
Prolly was drinking a little,, as they knew things were going south!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 7:21am
Appreciate all the replies! Yes she's a Power Shift and Front Assist.
So what I think it probably is now is a mid 83, but an 84 model year..?, Wanted to differentiate that for some reason by adding the '84' at the end.
Matt
